Author Topic: Brake disc replacement options  (Read 21574 times)
Offline JSYGTI
Re: Brake disc replacement options
« Reply #10 on: 21 September 2023, 06:45 »
That’s why I’ve been sticking with EBC pads, they don’t seem to create too much mess and have a good lifespan. For heavier cars like the mk6 I’d always go red stuff up front as it’s a harder compound and can run a higher temp before fading.
Offline Nino
  • Insta - F6UGA
« Reply #11 on: 21 September 2023, 11:06 »
I hate Redstuff installed on my MK4 R32 and I found they were awful until the brakes were hot  :cry:
Current - MK6 GTi Edition 35 - Candy White - 3 door.
Offline JSYGTI
« Reply #12 on: 21 September 2023, 12:14 »
OEM pads then, keep it simple.
Offline Nino
  • Insta - F6UGA
« Reply #13 on: 05 October 2023, 19:59 »
For people wondering incase you want to do it too.
I ended up purchasing Brembo UV painted discs.
More info on what this means Here
But in a nutshell;
When compared with discs with conventional corrosion protection , UV-coated discs ensure better resistance against corrosion, as confirmed by corrosion resistance testing in a salt spray chamber and moisture resistance tests. UV coating also clearly passes all tests with respect to resistance to high tempatures.
- Fronts: 10444226A
- Rears: 10444150A
And will be using these pads.
« Last Edit: 05 October 2023, 20:05 by Nino »
Offline JSYGTI
« Reply #14 on: 06 October 2023, 06:58 »
Looks like a good option, so the coating they have is similar to that on the Black Diamond disks?
How much did it all cost, if you don’t mind me asking?
Offline Nino
  • Insta - F6UGA
« Reply #15 on: 06 October 2023, 09:24 »
Exactly I did look up the APC Black diamond and felt that at the price point they are at, I could litreally upgrade to 6 pot :D
In terms of price, this is the crazy part. So, I looked in the normal places and they were coming in around £80-112 per disc for the fronts and £49-60 per disc for the rear. Honestly, I was happy to pay that but then I spotted them of all places in Halfords.... £180 all in (Not including pads) :shocked:
Click HERE for fronts.
Click HERE for rears.
Offline Nino
  • Insta - F6UGA
« Reply #16 on: 06 October 2023, 09:36 »
Just to add as well, I don't Think Halfords realise that they have these incorrectly priced ether.
I just triple checked as I doubted myself, on the side of the boxes are the model numbers.
- Fronts are: 09.9772.11
- Rear are: 08.A202.11
As you will see from these links from the officail Brembo website, they are confirmed the UV painted ones :)
- Front - https://www.bremboparts.com/europe/en/catalogue/disc/09-9772-11
- Rear - https://www.bremboparts.com/europe/en/catalogue/disc/08-A202-11
Offline Nino
  • Insta - F6UGA
« Reply #17 on: 08 October 2023, 08:13 »
Small update, Fitted ther fronts yesterday and everything was ok.
The rear discs were sadly 10mm to big. Have ordered the 272mm ones.
