Author Topic: Stop start not working.  (Read 3198 times)
Offline ianmb
« on: 12 June 2023, 17:25 »
Stop start not working,says power consumption is to high,car was up to temperature but it was a very hot day,
Car is 5years old was wondering if the battery was on the way out.
Offline mcmaddy
Re: Stop start not working.
« Reply #1 on: 12 June 2023, 18:20 »
Could be battery, could also be if you had your climate control on and it was working quite hard to cool then that could be the high energy consumption. Have you had your battery checked?
« Last Edit: 12 June 2023, 18:22 by mcmaddy »
Offline ianmb
« Reply #2 on: 12 June 2023, 18:52 »
The battery was tested at the last service in March and was ok then ,air con was on quite high.
Offline ianmb
« Reply #3 on: 12 June 2023, 18:57 »
Not sure if to get a c tech charger ,will have another go tomorrow.
Offline P6GTD
« Reply #4 on: 12 June 2023, 22:24 »
It’s quite common in my experience of GTIs for this to happen. After a short time on AC High the engine will run to maintain battery power.
It’s not a biggie.
Offline SRGTD
« Reply #5 on: 12 June 2023, 22:37 »
There are certain conditions that need to be met for stop start to work - these are probably listed in the owner’s manual.
There’s a list of generic conditions listed in the article at the link below - they’re not VW-specific, although the list in the owner’s manual is likely to be very similar if not the same.
https://www.carshop.co.uk/latest-news/stop-start/
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline madstaff
« Reply #6 on: 13 June 2023, 11:29 »
As already been said, your car has to meet certain conditions for start/stop to work.
I have noticed when i leave work and air con is working hard start/stop doesnt work, give it a while and then it works as expected, so sounds like normal behaviour.
Offline Adam T7
« Reply #7 on: 13 June 2023, 12:48 »
I always turn my off but this AM I got a message flashing up before I turned it off that it wasn’t working - went into the Car menu to see why just out of interest - message flashed up ‘Cabin to Humid’, I guess one of many reasons.
« Last Edit: 13 June 2023, 12:54 by Adam T7 »
Offline ianmb
« Reply #8 on: 16 June 2023, 15:04 »
Put the battery on trickle charge for a day, stop start started working straight away.
