Author Topic: Throttle body  (Read 6188 times)
Offline Bucko72
Throttle body
« on: 06 June 2023, 05:12 »
Hi guys after some technical advice. I have a mk6 gti and love it. It’s had a stage 1 and I’ve put scorpion exhaust on it. Runs sweet as most of the time. I was getting a 222 and 221 Ecu alarm. Replaced throttle body and accelerator pedal. Alarms have now gone. Most of the time runs sweet but sometimes looses a little bit of boost. My question is do they need to be calibrated/reset. Is there a trick to resetting. Excuse my ignorance for not knowing.
Offline Snoopy
  • Moderator
  • Geoff.
Re: Throttle body
« Reply #1 on: 06 June 2023, 07:52 »
From the thread above you comented on.
I missed that bit. Ask who ever fitted it if they did an adaption?
Watch below for why and how to do it.
https://www.youtube.com/watch?v=2zrmhDw_v7Y
Throttle body may need adaption.
But sounds more like you have a diverter valve that maybe going faulty which has a slight tear In the diaphragm.
« Last Edit: 06 June 2023, 07:54 by Snoopy »
Current Garage:
35+ years of GTI ownership.
Offline Bucko72
Re: Throttle body
« Reply #2 on: 06 June 2023, 08:03 »
Hi yes I have also been told that maybe the problem. Thank you for your help. I will replace diverted valve. Do you know of any recommendations to an upgraded one as it now been remapped.
Offline Snoopy
  • Moderator
  • Geoff.
Re: Throttle body
« Reply #3 on: 06 June 2023, 09:23 »
Others maybe able to advise better on which aftermarket ones, I've read good and bad about all of them over time.
Current Garage:
