Author Topic: GTI Caliper Decals  (Read 6419 times)
Offline Vw80
GTI Caliper Decals
« on: 29 May 2023, 21:46 »
Just wondering if anyone has replaced decals on PP calipers? Mine are bit faded and would like to freshen up. Where can replacements be sourced as VW is full caliper replacement.
Gti PP 2016 tornado red Dsg
Offline Ceefeesh
Re: GTI Caliper Decals
« Reply #1 on: 29 May 2023, 22:14 »
Here's a link to EZmods decals. I have used several of Eugene's products before, as have others on this forum, always top quality and quick service. I haven't used his caliper decals but I have used his sill covers and airbag delete sticker. First class.
https://www.ezmods.co/product-page/ezm-clubsport-s-front-brake-caliper-cover-decals-x-2-for-vw-golf-mk7-mk7-5-gti
« Last Edit: 29 May 2023, 22:16 by EngineCover »
Offline Vw80
« Reply #2 on: 30 May 2023, 22:28 »
Thanks for link an will shortly put in order. Has anyone experience of fitting new stickers? Has original sticker to be removed first or can new one be put directly over old 🤔. Should caliper be freshly painted first? Thanks.
Offline willni
« Reply #3 on: 31 May 2023, 08:29 »
The originals are painted on so no need to remove, just wipe down the plate with alcohol prior to fitting should be sufficient.
Offline Ceefeesh
« Reply #4 on: 31 May 2023, 08:58 »
All EZmod decals come with fitting instructions so they will assist. There are videos on Youtube too.
https://www.youtube.com/watch?v=ijxTWUICiTQ
Offline Jace
« Reply #5 on: 06 July 2023, 16:08 »
Also a 👍 for EZMODS
INSTA10  should get you 10% off  too
2018 Golf R 7.5 Estate > Full Revo stg2 set up
Offline Vw80
« Reply #6 on: 06 July 2023, 22:10 »
Received mine got stung for customs as am Eire based! Definitely look the part haven’t fitted yet as plan to have callipers re painted.
Offline Gulfstream11
« Reply #7 on: 07 July 2023, 11:07 »
Hi. Just ordered these, thank you for the link and code. I just want to know do you remove the factory decals first or just overlay them with the new ones.?
Previous rides..MKIV 1.8T   MKIV PD150  MK5 GTI MK5 edition30 now MK7 GTI PP
Offline Jace
« Reply #8 on: 18 July 2023, 15:37 »
Just clean the caliper with brake cleaner & apply over the factory logos as they are an exact size replacement .
The OEM logos aren't decals as such so you cant remove them
« Reply #9 on: 19 July 2023, 08:22 »
Thanks for the reply. It came with instructions the same as you described. Problem is I can't get round to doing them. Going to rotate the Tyres at the same time but rain keeps stopping play.
