Author Topic: Start / Stop not working? SOLVED !!  (Read 13782 times)
Offline fredgroves
Re: Start / Stop not working?
« Reply #10 on: 31 May 2023, 19:18 »
I don't think it can be done with obd11 any more actually on the mk8.
Conditions from the manual:
Quote
Vehicles with an automatic gearbox
When the vehicle is stationary, press and hold the brake pedal. The engine is stopped.
Take your foot off the brake pedal, or depress the accelerator, to restart the engine.
Important preconditions for automatic engine switch-off
The driver is wearing their seat belt.
The driver door is closed.
The bonnet is closed.
The factory-fitted towing bracket is not attached electrically to a trailer.
A minimum engine temperature has been reached.
The vehicle has been moved since the engine was last switched off.
For vehicles with Climatronic: the temperature inside the vehicle is within the pre-set temperature range.
The defrost function of the air conditioning system is not switched on.
The charging state of the vehicle battery is sufficient.
The temperature of the vehicle battery is not too low or too high.
The vehicle is not on a steep incline.
For vehicles with an automatic gearbox: the front wheels are not angled too sharply.
The windscreen heating is not switched on.
Reverse gear is not engaged.
The park assist system (Park Assist) system is not active.
When the conditions for automatic engine switch-off are only fulfilled when the vehicle is stationary, the engine can also switch off subsequently:
When the driver creates the required conditions by performing an action, e.g. by switching off the defrost function.
If the  button in the centre console is pressed twice  .
When selector lever position P is selected in vehicles with an automatic gearbox.
Offline fredgroves
« Reply #11 on: 31 May 2023, 19:19 »
Oh and sport mode also turns it off!
Offline monkeyhanger
« Reply #12 on: 31 May 2023, 21:45 »
Do you have anything fitted to the car that saps the battery, such as a dashcam with parking monitoring? I have a Dashcam with parking monitoring, set to cut out when the battery voltage falls to 12.3V. This is below the standard battery voltage threshold to allow stop start (in addition to engine oil temp thresholds.
So if you don't have a well topped up battery and warm oil, stop-start won't kick in - that makes stop-start kicking in a rare event for journeys less than 6 miles or if you have a dashcam nibbling at your battery capacity.
Offline TonyJ
Re: Start / Stop not working? SOLVED !!
« Reply #13 on: 31 May 2023, 22:25 »
Thanks to all for your replies !
By chance, I solved it today.
Until today, it has been quite warm and I have had the climate temperature set at "LO", sometimes with the aircon on and sometimes off.
However, today it was cooler, so I set a temperature of 17C, and the start/stop started working !
After a little investigation, it seems that if it set to "LO" , the start/stop will not work, but set it to a temperature, and it works !  It works whether or not the aircon is on.
This should perhaps be added to the list of conditions as shown in the user manual !
« Last Edit: 31 May 2023, 22:27 by TonyJ »
Current - Golf GTD Mk8
Previous - T-Roc R
Previous - Golf GTD Mk 7.5
Offline Carbon VW
« Reply #14 on: 01 June 2023, 07:49 »
Doh  :grin: leave the AC on all the time  :rolleyes:
Mk7 CSG GTi 6MF Stage 1, CSS backbox
Offline Adam T7
« Reply #15 on: 01 June 2023, 08:05 »
My missus is always turning her’s off - drives me to distraction.
