Author Topic: Headlights flickering  (Read 2973 times)
Offline mistertee
« on: 17 May 2023, 21:57 »
Hi,
I was driving home the other day in the dark, and I noticed something strange with the headlights, almost as if they were turning off (leaving the running lights on) just for a second or two, and then turning back on.
I got home and saw it happen, it's very intermittent, maybe once every 3 -5 minutes.  Both headlamps going out, then back on.  I thought it was the dusk sensor but I switched it from Auto and it still happened.
If it's both, it can't be the bulbs.  Is there anything else I can try?
Thanks
Offline willni
Re: Headlights flickering
« Reply #1 on: 18 May 2023, 14:48 »
Could be a loose connection to the ballasts
Offline Carbon VW
« Reply #2 on: 18 May 2023, 16:53 »
Hi,
Hi. How old is your gti ? When xenons are about to come to end of life they flicker when driving, but not completely on and off. Could be the ballast as already said.
Thanks
Mk7 CSG GTi 6MF Stage 1, CSS backbox
Offline mistertee
« Reply #3 on: 19 May 2023, 10:25 »
After a bit more investigation.
When I disable the dusk sensor, it's only happening on one side, so I think it's the bulb.
I've ordered a DS3 and will attempt to change it myself (thanks VW for making it so difficult).
I think the dusk sensor is a different issue, but as I can disable it, I'm not too worried.
Thanks all.
Offline mistertee
« Reply #4 on: 27 May 2023, 18:55 »
I've changed it myself, it was very fiddly but i just wanted to say that if you're doing this, tape up the lights. Theres a sharp edge on the light opening and taping then saved me scratching them
