Author Topic: DIAMOND CUT WHEELS - 6000 MILES - CORRODING  (Read 6191 times)
Offline Finglonga
Re: DIAMOND CUT WHEELS - 6000 MILES - CORRODING
« Reply #10 on: 06 March 2023, 15:08 »
Had two replaced on my MK7 at 40k at 60k they had all started to go again even the new ones. VW blamed stone chips and refused to do anything. No point getting them re-cut as they will go again so got them refurbished and Painted Bentley Grey last year.
Offline davo245
« Reply #11 on: 07 March 2023, 07:35 »
If the wheels are washed correctly and not kerbed or damaged they are fine I ran a set of serrons on my mk6  and mk7.5 GTI'ss as winters for the last 7 years still perfect no white worm or corrosion on any.
Bilberry ,wheel cleaner pressure wash off before contact wash and maybe something like autofinnese aqua coat on drying and they will last fine. Corrosion is caused by bad wash technique and wrong wheel cleaning products.
« Last Edit: 07 March 2023, 07:37 by davo245 »
Mk6 GTI DSG
MK7.5 GTI performance DSG
Mk8 GTI
Offline willni
« Reply #12 on: 07 March 2023, 08:20 »
Diamond Cut whiteworm / corrosion is cause by stone chips or kerbing marks thus breaking the lacquer finish, allowing water to get in behind overtime. As it's freshly cut metal underneath the lacquer the water marks the metal, making it look corroded and as well as making the remaining lacquer blister.
If you actually want to stop diamond cut damage you need paint protection film, but it's severely overkill imo.
Refinishing diamond cut alloys actually makes them more susceptible to whiteworm, as the lathe makes the sides of the spokes sharper so the lacquer doesn't bond as well to these edges, lacquer needs a nice smooth curve to bind well.
Offline SRGTD
« Reply #13 on: 07 March 2023, 08:30 »
I think luck plays a big part with diamond cut alloys.
Mine were never kerbed, I always used a safe wash technique and safe products, protected them well against the elements and touched in any stone chips as soon as they happened (black paint on the recessed sections and clear lacquer on the diamond cut faces). In spite of this, two of them suffered white worm - and not in areas where stone chips had been repaired.
IMHO a bare metal surface does not provide a good key for the clear lacquer to bond to - especially on the ‘sharp’ edges where the diamond cut face meets the recessed black painted sections - so durability is compromised compared to a powder coated alloy wheel. Also, diamond cut alloys seem to be much more susceptible to damage by tyre fitters than powder coated alloys (tyre fitters didn’t damage mine either, as they were still on the original tyres).
I don’t have any concerns with white worm now - within a few weeks of getting a new car I swap the factory diamond cut alloys for a set of durable powder coated alloys that I can run all year round with no worries of white worm. The diamond cut alloys go back on the car just before I sell it to add a bit of ‘bling’ for the next owner, if that’s their thing, and I sell the powder coated alloys on to recoup some of the cost incurred buying them.
« Last Edit: 07 March 2023, 08:35 by SRGTD »
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline mcmaddy
« Reply #14 on: 07 March 2023, 18:30 »
not every time. I've just had two Belvederes replaced as paint was lifting just next to the valve. My wheels are ceramic coated and washed very carefully every time.
