Author Topic: VAQ Diff not working, Possible?  (Read 15015 times)
Offline bogwoppit
Re: VAQ Diff not working, Possible?
« Reply #10 on: 26 February 2023, 13:33 »
If you know a fabricator they could make you a roller and you could try this:
https://www.youtube.com/watch?v=kVr8N0X22pg
BMW 128ti - current
Mk 7.5 GTI PP, indium grey, manual - gone
Offline EB2019
« Reply #11 on: 26 February 2023, 18:21 »
Thks Bogwoppit
I found this info, and will see if I can get the car on vagcom again, perhaps give it a reset?
Perform a pump relearn on a VAQ eLSD
https://www.jcr-leeds.com/how-to-service-front-elsd-full-guide/
« Last Edit: 26 February 2023, 18:25 by EB2019 »
Offline madstaff
« Reply #12 on: 26 February 2023, 19:34 »
I think a pump relearn is to be carried out after a filter clean.
This is so the pump control calibrates the power required to hit the target pressure.
Blocked filter = more power required due to the restriction.
Offline EB2019
« Reply #13 on: 26 February 2023, 19:41 »
ok thanks Madstaff!
Is there a chance they didn't do this after the service last year?  And that could cause it to not work correctly?
« Last Edit: 26 February 2023, 20:02 by EB2019 »
Offline madstaff
« Reply #14 on: 26 February 2023, 20:15 »
IMO i highly doubt VW remove the pump, clean the filter and perform a pump relearn.
I don't think VW dealers even acknowledge a diff service is required every 3 years TBH.
« Last Edit: 26 February 2023, 20:22 by madstaff »
Offline P6GTD
« Reply #15 on: 26 February 2023, 20:40 »
See other recent posts on this subject including my own recent experiences.
My dealer insists VAQ is a Borg Warner sealed for life item and does not appear on any service schedule.
Therefore they won’t touch front diffs unlike Haldex.
Their workshop techs confirm this.
As far as I’m concerned, they will continue to service the car and I will continue my VW extended warranty.
Maybe I’m wrong but “ if it ain’t broke, etc”
Offline EB2019
« Reply #16 on: 26 February 2023, 21:00 »
I can see this is going to get messy at the dealer, great  :rolleyes:
Offline madstaff
« Reply #17 on: 26 February 2023, 21:06 »
Offline EB2019
« Reply #18 on: 26 February 2023, 21:08 »
Sorry I meant would they do a relearn reset after a fluid change?  Or is it only when the pump is removed and filter cleaned?
thanks will have a read of the thread.
Offline madstaff
« Reply #19 on: 26 February 2023, 21:23 »
I doubt it as there is no mention of doing a pump relearn after a fluid change in the workshop manual.
Pump relearn after pump or gauze filter clean.
« Last Edit: 26 February 2023, 21:36 by madstaff »
