Author Topic: Engine cover!  (Read 117245 times)
Re: Engine cover!
« Reply #70 on: 02 May 2023, 20:59 »
The engine cover looks very snug in there!  :cool:
Offline davo245
Re: Engine cover!
« Reply #71 on: 02 May 2023, 22:30 »
So, the GTI is back from the dealership, they could not find any points of water ingress even though they tested for a whole week, I’m undecided as to whether that is a good or bad result considering there was (only once) a small amount of water on the inner rear door sill! 🤷🏼, however, the S3 engine cover 100% fits!,
I also asked the dealership to take a look at the fact that the heated seats appeared to switch on and off at various levels completely randomly, they have diagnosed it to be a faulty operating unit (J685), which is in fact the touchscreen, this will be replaced as and when under warranty at a cost of approximately £2000😳, it is currently on back order  :sad:
Good find that! What year s3 is if from did they not have the engine cover recall then so the audi covers of the same age are not  fire risk?
Do you ha  part number from it?
Mk6 GTI DSG
MK7.5 GTI performance DSG
Mk8 GTI
Offline Carlosfandango
Re: Engine cover!
« Reply #72 on: 02 May 2023, 22:35 »
Yes Exonian, It’s an absolutely spot on fit! Now I just need to think about whether I should leave the rings, or go ahead and add GTI lettering in its place? 🤔.
davo245, that’s something I did wonder, however it’s dated June 2022, so well after VW recalled their covers mid 2021, I’ll check the part number tomorrow and post it here.
« Last Edit: 02 May 2023, 22:43 by Carlosfandango »
Current -
Gone -
2022 Mk8 GTI DSG, Kings Red.
2003 Mk4 R32, Reflex Silver.
1991 AX GT.
1984 Mk1 XR2.
Plus many more.
Re: Engine cover!
« Reply #73 on: 03 May 2023, 06:05 »
Bearing in mind most of the under-bonnet ancillaries have Audi badges on them you might as well keep the four rings.
Mind you, I’m sure someone with a 3D printer could knock up a VW GTI badge that would fit over the four rings and keep it looking OEM VW.
Offline davo245
Re: Engine cover!
« Reply #74 on: 03 May 2023, 07:07 »
Thanks much appreciated 😁
Looks way better than the vw one!
Is it a hard plastic as opposed to the spongier vw one?
Mk6 GTI DSG
Mk8 GTI
Offline Adam T7
Re: Engine cover!
« Reply #75 on: 03 May 2023, 07:25 »
And the actual part cost to VW will be a fraction of £2K.
Re: Engine cover!
« Reply #76 on: 03 May 2023, 20:15 »
It’s sponge like the golf one, the red bits are hard plastic though, and are actually painted, and not just coloured plastic, the rings are hard plastic also, part number - 06Q 103 925 G.
Current -
Gone -
1991 AX GT.
1984 Mk1 XR2.
Plus many more.
Re: Engine cover!
« Reply #77 on: 04 May 2023, 05:00 »
Over on one of the T-Roc forums, a guy on there has had email confirmation from VW (see below), that the replacement covers (06Q 103 925 L) will start to be made available as of 8th may 23, so we may start receiving ours relatively soon, typically (for me) just as I’ve sourced an alternative! 🙄
Dear Mr *****
Thank you for your email. I can confirm that I have had notification from factory that the engine covers will be available from week 19 2023, week commencing 8 May.
I apologise for any inconvenience this has caused and your Volkswagen retailer will be in contact when the engine cover arrives to arrange a suitable date for it to be firted.
Kind regards
Debra Lynn
Customer Relations Manager
Executive Office
Volkswagen Customer Services Centre
Current -
Gone -
1991 AX GT.
1984 Mk1 XR2.
Plus many more.
Re: Engine cover!
« Reply #78 on: 04 May 2023, 05:19 »
Indeed!, they are of course quoting retail numbers, but even so, a touch panel like that wouldn’t cost anything like that much to produce, I hate to think how things will be for owners of any modern car of any brand once outside of warranty , long gone are the days that a faulty heated seat would have been down to a few physical components.
« Last Edit: 04 May 2023, 05:23 by Carlosfandango »
Current -
Gone -
1991 AX GT.
1984 Mk1 XR2.
Plus many more.
Offline Adam T7
Re: Engine cover!
« Reply #79 on: 04 May 2023, 08:34 »
Totally agree. Apparently it’s called ’progress’ 😂
