Author Topic: Clutch delay valve  (Read 2497 times)
Offline Riv151288
Clutch delay valve
« on: 27 October 2022, 11:02 »
Hi guys
Just wondered what the thoughts were on doing the clutch delay valve removal?
I have a uprated clutch set up on my car and a lot of posts ive seen across the internet is that its a must to remove delay valve to help better flow to the pedal
Vag sport do a aluminium block thats already got it deleted and was possibly think about getting that and they also do a braided clutch line
What do u guys think??
Offline Watts
Re: Clutch delay valve
« Reply #1 on: 27 October 2022, 15:17 »
Just take the valve out, that's free and easily reversible if you don't like it. One I didn't get around to. Taking the assistor spring off is worthwhile but the best and easiest I found was a bump stop for the clutch pedal. About £10ish on ebay, they reduce the pointless travel of the pedal. For me it also mean't getting a more comfortable position of the seat whilst still being able to fully depress the pedal. I'd also recommend adding an Audi short shift from a TT/S3.
Previously:
Offline Riv151288
« Reply #2 on: 27 October 2022, 17:09 »
Thanks for the reply watts
Yeah that is a another money Free option to just take the bit out thats in the standard part
Havent done the clutch stop, but i have removed the spring from the back of the clutch pedal
Am running a quickshift on the car which defo makes a nice bit of difference
Offline madstaff
« Reply #3 on: 27 October 2022, 18:48 »
@Watts Did you find this made the gearshift a bit "heavy or stiff" until it (the gearbox oil) had warmed up??
Offline Watts
« Reply #4 on: 27 October 2022, 20:31 »
It definitely made things firmer, more mechanical but I wouldn't say stiff. I really liked it.
Previously:
Offline madstaff
« Reply #5 on: 27 October 2022, 21:19 »
Thanks, i may have to look into this.  :smiley:
Offline Watts
« Reply #6 on: 28 October 2022, 06:20 »
Your ED40 may have it fitted as standard. I'd check first, the difference is not too difficult to see but you would need to remove the airbox. You can tell by the position of the upright post at the end of the lever. The post on the short shift is more inboard.
Comparison:
Previously:
Offline madstaff
« Reply #7 on: 28 October 2022, 08:37 »
Ahh yes i can see the difference, thanks, i'll have to take a look.
The word used to describe the feeling came to me on the way to work this morning - "notchy" when cold??
My MK2 had a short shift on and i found it to be a bit "notchy" when cold.
