Author Topic: Hot air from vents when HVAC switched off  (Read 8614 times)
Offline symonh2000
Re: Hot air from vents when HVAC switched off
« Reply #10 on: 23 October 2022, 13:24 »
Aircon uses more fuel. I know they are a lot better than they used to be but it is still load on the engine.
However I did read that if you do 60mph or more and have the window open it uses more fuel through drag than by using the aircon.
If you are using the car in town it will make a difference.
Golf GTI 7 PP
BMW M140i
Offline Watts
« Reply #11 on: 23 October 2022, 16:23 »
It goes off when I have the roof and windows open. Although the days of enjoying the wind in my hair are long gone, I love having the roof open and do so as often as I can.
It wasn't doing it today so perhaps there's something in the temperature that was set when it was switched off.
Previously:
Offline Rich62
« Reply #12 on: 24 October 2022, 11:49 »
Also noticed this happening earlier in the year and wondered why the car was getting so hot inside with HVAC off.
As mentioned above turning the temp to min before turning off seems to work for me to. I haven't found any other solutions, only comments that it's just a thing that this car does. Bit naff really isn't it, never had this issue with older and less premium brands of car.
Offline mcmaddy
« Reply #13 on: 24 October 2022, 16:03 »
Why are people turning climate control off?
Offline sjw
« Reply #14 on: 24 October 2022, 16:05 »
+1
Not saying it's the case for people on this forum, but the answer to that question is generally that they don't understand properly how it works.
Offline Watts
« Reply #15 on: 24 October 2022, 16:42 »
+1
I've addressed this already. Or perhaps you think I should have the aircon on with the windows and sunroof open?
Previously:
Offline symonh2000
« Reply #16 on: 24 October 2022, 17:21 »
You could spin this around and ask why are people leaving it on when it isn't needed, as doing so uses more fuel.
The fan also makes some noise, especially on 2 bars or above.
« Last Edit: 24 October 2022, 22:01 by symonh2000 »
Golf GTI 7 PP
BMW M140i
Offline mcmaddy
« Reply #17 on: 25 October 2022, 10:14 »
it doesn't use that much fuel really, I've never noticed any discernable difference in mpg. You maybe need to have the system checked if your fan is making a noise. You cause more issues by not using the climate control. Seals etc being one.
« Last Edit: 25 October 2022, 10:16 by mcmaddy »
Offline SRGTD
« Reply #18 on: 25 October 2022, 10:24 »
It’s not used just for its cooling properties - it also dehumidifies the air, so can be useful at this time of year when condensation on the inside of windows seems to be an issue in some cars.
I keep mine on 24/7 for the cooling effect in the warmer months and the dehumidifying effect in the colder months.
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline Adam T7
« Reply #19 on: 25 October 2022, 11:31 »
The gas is also a lubricant, maintains seals etc. - mine is constantly on. If you flick through the Car menu you can see how much fuel is being used by convenience consumers - it’s 3/5ths of FA for the climate control.
« Last Edit: 25 October 2022, 12:06 by Adam T7 »
