Author Topic: creaking suspension  (Read 4698 times)
Offline symonh2000
creaking suspension
« on: 12 September 2022, 08:13 »
Does anyone else here suffer creaks from their suspension?
I seem to be getting noises from both the front and rear on undulating roads, and over speed humps.
It sounds like a bed getting a good hammering.
I have a tin of silicone spray, is it worth going around the bushes and links and giving them a good spraying?
There is also a noise which seems to be coming from the hatch, and it is worse in colder weather.
Thank you in advance. :)
Golf GTI 7 PP
BMW M140i
Offline madstaff
Re: creaking suspension
« Reply #1 on: 12 September 2022, 08:54 »
Do you have DCC by any chance??
My front suspension creaks going over bumps and when reversing on my drive whilst turning.
Ive think its the front top mounts, or maybe the front wishbone rear bushes.
Ive tried the silicone spray treatment and didnt notice any change.
There is a TPI out regarding wishbone bushes which basically says to fill the bush voids with some expensive lithium grease.
The workshop manual regarding the lubricating of the control arm rear bushes.
Offline davo245
« Reply #2 on: 12 September 2022, 09:04 »
I had this done under warranty for front wishbone buses the grease cures it for a short while took it back in and they changed the front radius arms .
The latest version of the arms has been changed to cure the issue.
Mine has been fin since ( 2018 gti PP DCC)
Mk6 GTI DSG
MK7.5 GTI performance DSG
Mk8 GTI
Offline symonh2000
« Reply #3 on: 12 September 2022, 09:48 »
No it doesn't have DCC
Thanks for the tip on the front bushes.
I am falling out of love with this car at the moment, it seems to be suffering from quite a few annoying niggles.
Such a shame as it is a great car otherwise.
Golf GTI 7 PP
BMW M140i
Offline Dazie00
« Reply #4 on: 21 September 2022, 07:02 »
This is interesting to me as i have had these issues for a while now, having spent plenty on new shocks, top mounts and drop links plus the harmonic  damper , my garage has just found this also
Greased up the bushes , done 1500 miles and it's back to how it was !
 So have new control arms coming with super pro bushes , Lets see how that goes !!
GTI PP, Leather, Pan roof, Rev Camera, Keyless , MIB2
Gone but not forgotten
GTI 5 Man
R 7 DSG stage 1
GTI 5 DSG
RS4 B7
GTI 4 1.8T
GTI 3
GTI 1 CAB
Offline symonh2000
« Reply #5 on: 21 September 2022, 07:48 »
Mine has creaks from both the front and rear, but the rear is by far the worst. It almost sounds like it could be the tailgate.
Not what you would expect on a lowish mileage car.  :sad:
Golf GTI 7 PP
BMW M140i
Offline Rudedog
« Reply #6 on: 21 September 2022, 08:26 »
Finally bit the bullet and got mine booked in at the end of October (first time with a car free).
Mine has a creak when parking and I'm on full-lock left (loud) or right (slightly), definitely sounds like its coming from the front high up as if its 'adjusting or settling' also get it on full lock left when coming down a multi-story carpark.
I've already had the main subframe bolts removed and greased as per a TPI which did help with the creaking I had when braking before turning in.
I've mentioned this issue before but with other problems and I think the dealer has said they couldn't hear it so this time I've just booked it in for this issue alone.
I took out a two year extended warranty when I bought the car so I'm hoping this will be covered by this.
Offline Dazie00
« Reply #7 on: 21 September 2022, 16:33 »
I didn't realise that there was a TPI on subframe bolts as well!!
GTI 5 Man
R 7 DSG stage 1
GTI 5 DSG
RS4 B7
GTI 4 1.8T
GTI 3
GTI 1 CAB
Offline madstaff
« Reply #8 on: 21 September 2022, 17:34 »
Me neither, anyone able to post up any more details about this TPI??
Offline symonh2000
« Reply #9 on: 25 October 2022, 07:21 »
An update on my car.
I have significantly reduced the noise on my car. I was suspicious that most of it was coming from the rear hatch, and I have managed to cure that by adding white spray grease to the boot catch.
Now onto the suspension creaks...
Golf GTI 7 PP
BMW M140i
