Author Topic: Cruise control retro fit  (Read 12393 times)
Offline Mileymk6
« on: 12 July 2022, 11:27 »
Hi
I have a 2010 mk6 and am wanting cruise control fitting, back in 2007 when I bought my first mk5 from the main dealers they fitted it for around £150 as a retro fit, apparently just needed a new stalk and programming.
Is it the same situation with the mk6?
Cheera
2010 Mk6 3Dr, Blue graphite, 18” Monzas, rns310 Dab with Dynaudio, standard apart from Stainless exhaust. Called Miley cos it’s done a lot of miles!!
Offline jv
  • Administrator
Re: Cruise control retro fit
« Reply #1 on: 12 July 2022, 13:02 »
Not sure main dealers will care for that sort of stuff anymore but others will eg:
https://www.vw-retrofit.co.uk/product/golf-mk6-cruise-control-kit-supply-and-fit-copy/
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline Mileymk6
« Reply #2 on: 12 July 2022, 13:30 »
Thanks for that, not really been able to find anywhere who could do it.
Offline Bluto
« Reply #3 on: 12 July 2022, 14:32 »
Hi Mileymk6, my main dealer retrofitted Cruise Control on my current 2009 Mk6.  A new stalk and some coding as far as I'm aware.  Was a while ago though in 2018.  The main dealer was Parkway Volkswagen if that helps; not sure if you're in the UK?
As jv says depends on the appetite from garages to do it, but worth an ask.
Bluto
Mk8 GTI Clubsport | Pure White | DCC | Black Estorils | HUD | a fair few options
Previous: Mk6 GTI | Candy White | Manual | DCC | Dynaudio | Cruise | Winter Pack | Lux Pack | Rear Camera & F/R Parking Sensors
Offline Mileymk6
« Reply #4 on: 12 July 2022, 15:14 »
Yeah in the uk, Weat Yorkshire to be precise.
I am also looking at getting heated seats retro fitted and rear pdc as I am now so used to having them!!
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #5 on: 12 July 2022, 17:31 »
Depends when in 2010 the car was built. Early had the same double stalks as the mk5 sonthe same procedure. Later they changed to the all in one which is alot more expensive to retrofit cruise too.
Current Garage:
35+ years of GTI ownership.
Offline Mileymk6
« Reply #6 on: 12 July 2022, 17:41 »
How can you tell the difference?looks exactly the same as my mk5’s did.
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #7 on: 12 July 2022, 18:03 »
only £60 more for the later one peace stalks over the two peace ones that has reduced alot over the years use to be hundreds more.  :smiley:
Quite a few retrofit companys about doing VWs now so a quick Google search if this ones nit near enough for the original poster.
Current Garage:
Offline dubber36
« Reply #8 on: 13 July 2022, 14:01 »
From memory, the early stalks would stay clicked forwards when you turn on main beam. From 2010MY onwards, when the stalk is pushed forwards, it springs back to the central position.
Offline joe6
« Reply #9 on: 14 July 2022, 08:49 »
If your car is a 2010 build then you only require the single stalk. Have had to replace mine recently because it developed a fault. It was a factory fitted option. Quite cheap for an aftermarket one - about £27. Not sure if you need to replace the control module under the steering column. Needs coding in. If you have VCDS then the long coding helper sorts this out. To check if you need a different control module try coding cc using vcds or obd11. It will not let you do it if incorrect module. I can check what module number I have if that helps. Think it is the highline one.
