Author Topic: Noisy rear suspension ???  (Read 3743 times)
Offline Dazie00
« on: 11 July 2022, 07:16 »
I've had a few noise issues with what i think is coming from rear end, a bit like scuttle shake, not always on hard hits or terrible roads, had it all checked over and had front shocks changed and also calliper sliders, rear shocks seem fine and are not leaking or sagging at all, everything is fine and tight underneath , I have read about a harmonic rear damper
Does it make much difference?
Is this a common issue with Mk7 gti s ?
Any other ideas ???
Thanks
Daz
GTI PP, Leather, Pan roof, Rev Camera, Keyless , MIB2
Gone but not forgotten
GTI 5 Man
R 7 DSG stage 1
GTI 5 DSG
RS4 B7
GTI 4 1.8T
GTI 3
GTI 1 CAB
Offline symonh2000
Re: Noisy rear suspension ???
« Reply #1 on: 11 July 2022, 07:51 »
I have a noise on mine at the rear too, mostly at slower speeds. It sounds like it could be the rear anti roll bar bushes creaking.
I am interested to see how you get on, I was planning on spraying silicone spray up under mine to see if I can fix it.
Golf GTI 7 PP
BMW M140i
Online Watts
« Reply #2 on: 11 July 2022, 10:00 »
I had a damper fitted last week. It has definitely made the rear end quieter. Now most road noise comes from the front. Can't say it is the solution to your problem but it's well worth trying, especially if you can fit it yourself. There's lots of information about them here - https://www.golfgtiforum.co.uk/index.php?topic=285982.0
Previously:
Offline symonh2000
« Reply #3 on: 11 July 2022, 11:28 »
I was thinking, this damper is just a lump of metal with a couple of bushes pressed in.
I wonder how easy it would be to make one from a piece of stainless instead of forking out the £70 odd for one.
Golf GTI 7 PP
BMW M140i
Offline madstaff
« Reply #4 on: 11 July 2022, 14:00 »
I think its more than just a big lump of metal!!
It'll have been specifically "tuned" and be of a certain weight to cancel out a vibration occuring at a particular speed/rpm.
Offline o`Neil
« Reply #5 on: 11 July 2022, 18:51 »
Are you Scottish?  :wink:
Offline symonh2000
« Reply #6 on: 11 July 2022, 21:58 »
No but £70 is £70.  :smiley:
For something that might or might not fix a problem that may or may not exist.
Any additional mass with change the resonant frequency of the subframe, so my guess is that a similar mass of bolted up would be worth a try and would be a lot cheaper.
Golf GTI 7 PP
BMW M140i
Offline Finglonga
« Reply #7 on: 12 July 2022, 23:52 »
It is but it is also fully bushed so it can move at it's own frequency to remove harmonics. Also would need to be a specific weight as well to match the sub frame harmonics. Not worth the hassle and it is a doddle to fit and on mine made a huge difference.
Offline Dazie00
« Reply #8 on: 21 September 2022, 07:15 »
Well the harmonic damper didn't fix my problem and having now changed virtually all suspension parts , we have hopefully narrowed it down to the front control arms
Had this done last week and it fixed it for a while so new ones coming with polybushes  to  touch wood prevent further issues!
GTI 5 Man
R 7 DSG stage 1
GTI 5 DSG
RS4 B7
GTI 4 1.8T
GTI 3
GTI 1 CAB
