Author Topic: 2-3 loud clunks engine bay single time after i turn car on and start driving  (Read 7962 times)
Offline Speeds
I have Golf 8 GTI Clubsport every single time after i turn car on and start driving, i hear like 2-3 loud clunks as if something is clicking in the engine bay. taking it in for service to next week, it just doesn't sound normal.
Offline fredgroves
It happens about 100 yards after you pull away and sounds like the landing gear coming up?
It's the power steering pump pressurising apparently. I read a tpi about it as I was worried too. It's normal.
Offline Speeds
Thanks, do you have TPI code? It sounds very hard. My Mk7 i never heard it before.
Offline fredgroves
I don't, but I remember reading it a while back when I was hunting for if the suspension rattle was documented...
Offline Foxy367
  • Here All Week
Is it possible to get access to the TPI's as a general punter?
Current - Awaiting a milkfloat
Previously
2021 Mk8 GTI Clubsport - Atlantic Blue
2017 MK7.5 GTI Performance - Tornado Red
First steps into Golf ownership -
2003 Mk4 GtTdi PD150 Oceanic Green
2002 Mk4 GtTdi PD150 Reflex silver
Offline fredgroves
Technical product information : 2029747/4 2029747/4
Service info: running gear - rattling/jarring noises from front of vehicle when pulling away for first time after start
Release date: 16-Dec-2020
Customer statement:
• Briefly after pulling away for the first time after the engine start a rattling or jarring noise can be heard
from the front of the vehicle.
Workshop findings:
• The customer statement can be reproduced.
: Type of change:
2029747/4
Technical background
Shortly after pulling away for the first time after the engine start the anti-lock brake system (ABS)/electronic
stabilisation control (ESC) performs a short self-check in which all valves of the hydraulic unit are activated
and the return pump briefly starts up. This system-related behaviour is sometimes perceived as rattling or
jarring noise.
The self-check is necessary for a correct operation of the ABS/ESC system. The resulting The self-check is necessary for a correct operation of the ABS/ESC system. The resulting working noises are normal. The working noises are construction-related and normal. There is working noises are normal. There is no parts damage.
« Last Edit: 04 July 2022, 18:18 by fredgroves »
Offline fredgroves
You need an Erwin login, which costs money... or someone who already has one.
I had a login for a while and was downloading the training manuals.
Offline Speeds
Unbelievable, how do they can make it like this. Golf 7 does not has this problem.
Offline fredgroves
I'd not call it a "problem"
I suspect its all part of GSR 2019.
Offline Speeds
In my opinion it is ridiculous that a car of 55000,- euros makes a noise every first start that you think is something under the hood falls to the ground. This is the first car I drive where I hear this. And I understand that VW types a piece of text with the problem. They would rather do that than solve the problem. It seems to me that they can also make it without sound.
