Author Topic: DSG tune  (Read 7887 times)
Offline Watts
Re: DSG tune
« Reply #10 on: 17 June 2022, 06:19 »
A couple of things, one where in the US where was a phenomenal amount of faffing around getting the tune with a lot of back and forth to the Netherlands to get it installed and then it seemed to be the wrong tune, someone else wasn't happy as after a while it seemed to have taken on very much stock like properties. There were though others saying how great the stage 2+ tune was so I'm not saying it was all bad but finding decent objective reviews on any TCU remap seems tricky, especially on an otherwise stock car.
I'm not so bothered about making changes to the way sport works, or launching it faster, I was just hoping that regular off the line driving could be smoothed out.
Previously:
Offline dubber36
Re: DSG tune
« Reply #11 on: 17 June 2022, 14:32 »
I've read nothing but good things about the TVS map that Oli at Bognor Motors has installed on many a Transporter as well as his own TCR.
Offline Watts
Re: DSG tune
« Reply #12 on: 17 June 2022, 19:13 »
Thanks.
Previously:
Offline Ej1749
  • Hey all! I may need some help.
Re: DSG tune
« Reply #13 on: 18 June 2022, 19:06 »
I find the gearbox to be rather juddery at low speeds and you can feel it slipping the clutch plus sport mode is a bit too aggresive. At the least I'd like it to be smoother at bimbling speeds. Does anyone have first hand experience of the tunes and will they improve these aspects?
Sounds counter intuitive, the only time I experienced less slip was when I had a but I’d turbo, I think because the turbo would come on strong, but it would be as aggressive - just as an FYI
GOLF GTD 65 MK7 STAGE 1
Re: DSG tune
« Reply #14 on: 18 June 2022, 22:49 »
Indeed, unless engine tuned and in need of extra clamping force or a bit of aggression under full fat acceleration (probably on closed circuit or drag strip use) then Sport is good enough as is.
I totally got where you were coming from with this thread.
The desire to remove that indecisiveness at normal driving speed and occasional clutch slip as the box goes through the gears too quickly when you want to get up to speed in a leisurely but positive fashion.
I’d imagine there would be a lot of requests for a mid-point setting that’s less aggressive than sport but more positive feeling than normal or comfort.
I think DTE/DTUK do a plug in DSG tune, or at least they used to. I’ve no idea what sort of improvement or otherwise this unit would bring.
Offline mcmaddy
Re: DSG tune
« Reply #15 on: 19 June 2022, 16:29 »
I wouldn't go anywhere near anything dtuk are flogging. With something as expensive and important as the dsg gearbox you want a company that knows what's it's doing. Dtuk definitely don't fall into that category!
Re: DSG tune
« Reply #16 on: 20 June 2022, 18:40 »
I’m saying nothing….   :evil:
Offline mcmaddy
Re: DSG tune
« Reply #17 on: 20 June 2022, 19:19 »
Offline Ej1749
Re: DSG tune
« Reply #18 on: 29 June 2022, 13:56 »
My stage 1 GTD occasionally slips underload very slightly in 2nd, but not 1st which is bizarre. My 2015 S3 and my current GTD are/were both a bit juddery when cold. My GTD feels like it is going to stall as I stop at the junction leaving my estate. It is fine after about 2-3 mins though.
I have noticed that in town driving and slow stop start traffic if your autohold is turned on, then trying to gently pull away is very jerky, especially if you are using DCC.
Offline Jace
Re: DSG tune
« Reply #19 on: 01 July 2022, 13:54 »
I have a REVO TCU map in my stg2 7.5 R estate & it works very well with the REVO engine software.
Depending on how old your car is & if it has the 7 speed DQ381 gearbox VW are actually doing a software update on these now, I took mine for MOT on Monday at a VW dealer & they asked me if I wanted it uploading, which I didn't as its already running the Revo tune.
Contact your local main VW dealer & check
2018 Golf R 7.5 Estate > Full Revo stg2 set up
