Author Topic: Seized  (Read 1067 times)
Offline kkh120
Seized
« on: 19 October 2005, 14:48 »
The locking nut on the tracking arm has seized and now a bit round as well :cry:
Any ideas how to remove it?
Mk2 8v and 16v.
Always looking for bits!
Offline kniterider
  • had most, sold most and often buy more!
Re: Seized
« Reply #1 on: 19 October 2005, 14:57 »
if you cant shift it with a decent set of mole grips then try some stilsons if they wont shift it its time for some heat...... i take it you put plenty of wd40 etc on it to soak before youve tried to undo it, also check which way the threads go as to wether its lefthand thread or right hand..
 :smiley:
Offline kkh120
Re: Seized
« Reply #2 on: 19 October 2005, 16:04 »
I just assumed it was right hand thread!
Yea, lots of wd40. Was going to try and cut off the nut, soak again with wd40 then try and remove the tie rod end (if thats the right name) and screw on a new locking nut.
Worth a go?
Mk2 8v and 16v.
Offline Mr Blue
Re: Seized
« Reply #3 on: 19 October 2005, 17:23 »
get the hammer out and beat it one  :angry: :laugh:
Offline Organisys
  • Old and Slow...
Re: Seized
« Reply #4 on: 19 October 2005, 21:50 »
Offline RYoungMK1GTI
  • Mk1 Golfs R still the Best
Re: Seized
« Reply #5 on: 19 October 2005, 22:17 »
use a bottle jack on top of the track rod end and jack it up into the inner arch this will push the taper of the ball joint further so it wont spin then use an inpact gun to buzz it off this always worksand is not.  An angle grinder.
Offline kkh120
Re: Seized
« Reply #6 on: 20 October 2005, 10:04 »
Quote
Check this out
http://www.frost.co.uk/item_Detail.asp?productID=7976
Nice job, but can't get it over the tie rod end unfortunately.
Quote
use an inpact gun
I only wish I had one of those!
Mk2 8v and 16v.
Offline jasonpi
Re: Seized
« Reply #7 on: 21 October 2005, 09:56 »
use a smaller socket and whack it on with some force maybe it will work
