Author Topic: Mk2 16v cold start up problems  (Read 13651 times)
Offline Skul1
« on: 09 April 2022, 10:53 »
Hi there, my mk2 16v high tech has a problem on cold start up.
It has to spin for ages before starts up, and then the idle is fine but has a bad response when i accelerate.
I have to wait till it warms up, otherwise the response is bad, very chokey. When its warm the car runs and starts fine with any problem.
I have already change th 5th injector but the problem remains.
Any idea? Thanks
Offline dubber36
Re: Mk2 16v cold start up problems
« Reply #1 on: 09 April 2022, 17:41 »
Have you checked the ignition timing?
Offline Skul1
« Reply #2 on: 09 April 2022, 21:45 »
No I didn't. Do you think it could be the problem?
Offline dubber36
« Reply #3 on: 11 April 2022, 10:10 »
Mine used to do something similar. The timing was quite a bit out, plus it was running a bit too lean. They prefer to run a little richer than some MOT stations are happy to let through.
