Author Topic: Is there any way to know if dipped beams are on?  (Read 5455 times)
Offline martin998877
Re: Is there any way to know if dipped beams are on?
« Reply #10 on: 25 February 2022, 21:00 »
The light on my switch is on all the time, as far as I can tell. I wonder if the coding of the rear lights to be always on cou ld have changed this behaviour. I'm pretty sure it's always been like that, though.
Exactly this - if you code the rear lights to always be on, then the green 'headlights on' indicator on the light swich is always on when in Auto, rather than responding to theheadlight status.
I preferred knowing when the headlights were on, so cancelled the coding for 'rear lights on with DRLs'.
Golf GTi Mark 7 owner
Offline itavaltalainen
« Reply #11 on: 28 February 2022, 07:18 »
You can code the rears to be on without turning the green status  light on.
Just a different way of coding (add the drf function to the two light channels rather than telling the car that drl should turn rears on too).
Offline sjw
« Reply #12 on: 28 February 2022, 11:19 »
Sounds like that is what I need to do. Do you have any instructions? I'll get around to it at some point. Cheers.
