Author Topic: Mk 7 / 7.5 Remus Rear box delete  (Read 5169 times)
Offline Proctor
« on: 19 February 2022, 21:06 »
Remus rear box delete with Black chrome 102mm tips. I bought this from Motech Performance, was fitted to my car for 6 months (some slight wear but no damage or scuffs) and been in the garage since
OEM system will need cutting to fit but all clips included to fit, I’ve changed back to OEM
£450 Ono
« Last Edit: 21 February 2022, 10:55 by Proctor »
Offline Proctor
Re: Mk 7 / 7.5 Remus Rear box delete
« Reply #1 on: 20 February 2022, 11:33 »
WhatsApp ; 07805450991
Offline willni
« Reply #2 on: 20 February 2022, 19:55 »
Mk7 and 7.5 exhausts are different widths so they aren't interchangeable, best putting the remus part number from your Motech receipt up.
Offline Proctor
« Reply #3 on: 21 February 2022, 11:01 »
Looking through a lot of different websites including Remus, this is compatible for Golf GTI Mk7 / 7.5 and Leon Cupra.. This increases the Pipework Diameter from the stock 65mm to 70mm
Offline Agreeable Slick
  • Unit
« Reply #4 on: 21 February 2022, 13:44 »
Pipe diameter might be the same, but the distance between centres of the two outlets is different between 7 & 7.5, I cannot remember off the top of my head by how much though.
Offline Proctor
« Reply #5 on: 21 February 2022, 13:59 »
The distance between the two outlets can be changed, the exhaust comes in 4 sections.. Pipe to centre T piece, T piece and then each side with the tips clipped on at the end. This distance can be changed but loosening the jubilee clips in the middle 👍🏼
If you look at the first image, you can see the clips etc
