Author Topic: Sudden Increase In Exhaust Noise  (Read 46479 times)
Offline Carbon VW
Re: Sudden Increase In Exhaust Noise
« Reply #10 on: 23 February 2022, 15:37 »
Just to report back…..extra noise disappeared as mysteriously as it appeared after 24hrs.
Dealer checked during first MOT today and reported no fault could be found.
My wife says I have an over active imagination!
I tend to agree with your wife  :grin: :grin: :grin:
Mk7 CSG GTi 6MF Stage 1, CSS backbox
Offline skippy
« Reply #11 on: 30 November 2025, 21:23 »
Hello all, experienced these symptoms for the first time on my MK7.5 GTI this weekend in almost 6 years of ownership, I am sure it is a regen.
Car was not as smooth running as normal and as per discussion previously, fuel consumption has fallen off a cliff! Most of the running I was in high 20's and only just crept over 30mpg once reaching home.
I had not used the car much during November, 8 miles in 3 weeks I think. Did a decent'ish run today of about 17 miles each way (gap of 4 hours or so between), but the regen operation is still there. Traffic and my route was such I could not get a sustained high's rpm to clear it. Think I need to take it for a blast to complete it, as the car really does not perform any where near as efficiently while performing a regen.
MK7.5 2020, Isaac Blue, standard spec
Gone but certainly not forgotten Candy White Scirocco 2.0 TSI
Offline SRGTD
« Reply #12 on: 30 November 2025, 21:57 »
It does sound like a GPF / OPF regeneration. In addition to lumpy running and poor mpg, there are other tell tale signs of a GPF regeneration - outlined in my post (reply #6) in the discussion topic at the link below.
Unlike diesel particulate filters where blast at sustained high rpm’s does help to clear the DPF, IMHO it’s not the best way to clear the GPF in a VAG petrol engined car - the process outlined towards the end of my post (reply #6) in the linked topic has worked for me and for other forum members too.
https://www.golfgtiforum.co.uk/index.php?topic=290349.msg2665390#msg2665390
Also, be aware that if you happen to switch off the engine while a regen is in progress, the regen will recommence during the next (and subsequent) ignition cycle(s) until it’s finished. Therefore, if you’re aware of a regen in progress when you’re nearing the end of your journey IMHO it’s best best to extend your journey so the regen can run its course before switching off your engine.
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline skippy
« Reply #13 on: 30 November 2025, 22:25 »
Thank you so much SRGTD, you always give such a detailed analysis to forum members questions!
I will heed your advice on that one and optimise engine braking. It was a bit strange in that in almost 6 years of ownership, I had yet to experience this. The car tends to sit in the week and gets used on longish runs at the weekends, I try and avoid short stop/start journeys if possible.
We are soon selling my wife’s car (Polo GTI of 2010 vintage) so we have been getting the maximum use out of it for the last time leaving my Golf pretty idle during November. Only yesterday I noticed the increased tickover speed and the obvious increase of resonance from the exhaust!
Thank you so much again for your reply!
Offline Watts
« Reply #14 on: 30 November 2025, 22:32 »
Having heeded SRGTD's advice on regens I can confirm it worked perfectly for me. Spot on advice as usual :smiley:
Previously:
Offline SRGTD
« Reply #15 on: 30 November 2025, 22:37 »
You’re very welcome  :smiley:.
Good to hear it worked for you @Watts  :smiley:.
Offline skippy
« Reply #16 on: 01 December 2025, 10:51 »
Thank you very much both, I will report back in a few days time, but confident it will sort it.
I did not really enjoy the driving experience I must admit compared to normal. The power was definitely not as sharp as usual, and seeing the range dropping by 5 mile  increments every few minutes it seemed was alarming!
Offline skippy
« Reply #17 on: 09 December 2025, 21:52 »
Hello SRGTD & Watts,
I can confirm that your solution to the exhaust noise increase (caused by the active regeneration) was successful and mpg has returned back to normal.
Took the car for a longer run last Sunday and for me at least, I was a bit more aggressive on the downshift to get the revs up. I am very mechanically sympathetic normally and tend to not venture too far up the rev range.
It did take quite a while to clear, but the overall average mpg always remained low anyway, but I saw it creep up to 34mpg at the end of the run which was an improvement. Took it out tonight and almost without trying I was up to 43mpg!
It is due for service soon, and suspected the garage may have done an Italian tuneup for me to clear it!  :laugh:
Thank you very much again for your responses!
Offline Watts
« Reply #18 on: 09 December 2025, 22:03 »
Great stuff! :smiley:
Previously:
Offline SRGTD
« Reply #19 on: 10 December 2025, 13:33 »
