Author Topic: Differential service  (Read 50278 times)
Offline Adam T7
Re: Differential service
« Reply #60 on: 07 September 2022, 12:10 »
Worrying they didn’t know your TCR had an LSD. Get it in writing they will clean the filter and ask for a picture.
Offline madstaff
« Reply #61 on: 07 September 2022, 14:04 »
As removing the pump is not part of the official documented procedure for a diff oil change your VW dealer will be reluctant to do it, unless your dealer is accommodating and agrees to do it.
Probably adding the cost of a fill plug, a drain plug and the 2 pump "O" rings to the bill too.
I wonder how many do the pump relearn procedure too??
Offline Adam T7
« Reply #62 on: 07 September 2022, 14:16 »
The reason I got a decent local independent to do mine.
Offline funboxster
« Reply #63 on: 07 September 2022, 14:55 »
Thanks Madstaff again
As they've literally just rung to say car all done, I'll check to see if they've charged me for those items!
Pure White MY 2020 GTI TCR 19" Reifnitz with DCC, Pan Roof and Climate Windscreen
Offline bogwoppit
« Reply #64 on: 07 September 2022, 17:34 »
Ours was done yesterday at an independent -VAG Autocare services, I decided to move away from the main dealers.
I asked for the pump to be removed to clean the gauze, as well as the fluid change.
This was taken before the gauze was wiped, as you can see it's pretty clean.
This is at 3 yrs, 2 months old, 17,100 miles.
« Last Edit: 07 September 2022, 17:37 by bogwoppit »
BMW 128ti - current
Mk 7.5 GTI PP, indium grey, manual - gone
