Author Topic: Vag mechanic SE London/Kent  (Read 3476 times)
Offline Amssxi
« on: 06 December 2021, 20:29 »
Any recommendations for a VAG mechanic around SE London or Kent area, ideally someone with vagcom
Offline jv
  • Administrator
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline fredgroves
Re: Vag mechanic SE London/Kent
« Reply #2 on: 01 February 2022, 09:53 »
AMD are good. I knew them because they used to race in BTCC.
Offline Agreeable Slick
  • Unit
« Reply #4 on: 01 February 2022, 17:55 »
A quick search came up with this https://www.google.co.uk/search?q=gynaecologists+south+east+London&ie=UTF-8&oe=UTF-8&hl=en-gb&client=safari but I’m not sure if many of those places use that type of software to detect issues with your vag.
Or did you mean VAG mechanic?  :whistle:
There are a lot of helpful people on here and probably some that have their own software in that geographic area that might be able to help at a lot less cost depending on what the issue is.
Most of the big VAG indies will have at least VCDS grade software and many will have far more advanced stuff. Even many backstreet garages have VCDS these days or at the very minimum they’ll have generic OBD 11 readers.
If you perhaps posted up the actual issue then possibly you could get some good pointers on here of who would be the best in that specific field.
