Author Topic: Micro cracking on Tyres?  (Read 15872 times)
Offline baka
Re: Micro cracking on Tyres?
« Reply #20 on: 01 December 2021, 14:42 »
Yup, pretty much.  :whistle:
Offline davo245
« Reply #21 on: 31 March 2024, 21:11 »
Hey guys, looking for a bit of advice. When my GTI had it's 1st MOT back in May this year, whilst it passed and had no official advisories, the tester did make a comment that 3 of the 4 tyres were showing signs of cracking on the outer tread blocks, and he said if it got any worse, it could be an MOT failure next year. Now to be honest, I sort of forgot, but when I was cleaning the car the other day, remembered and had a good look, and sure enough 3 tyres display some quite heavy cracking.
The tyres are all the factory original Pirelli P-Zero's (225x35x19) and all all date stamped 01/18 (car was built in April 18, and 1st registered in May 18). Now I know they are over 3 years old, and have 20k miles on them, and most folk I'm sure would just say replace them, but the trouble is all 3 affected tyres still have nearly 5mm on them (lowest has 4.5mm) so no where near worn out yet and still give decent grip. The reason why 3 have gone and not 4, is that the nearside front tyre was replaced early 2019 following a puncture so that has a different build date. Despite this tyre having done over 13,000 miles itself, it's displaying no cracking at all.
Do you guys think this is a manufacturing defect or just the way the car's geometry is set up (although wouldn't explain why the new tyre isn't affected) ? BTW, it's literally just the outer tread block. The remaining 75% of the tread is perfect and none of the 3 main tread grooves display and signs of cracking around the circumference of the tyre ? I'm fairly certain it's not damage due to chemicals as my tyre shine is water based and I don't cover the inside tread block - just the walls. What do you guys think ?
Pictures below:
Thread bump on this.
I have a MK8 Gti with the factory Hankook Ventus evo's on 28k ( swopped front to rear) .
They have started to look like this photo too. Not to worried as have some new Michelins ready to go on but just wondering if anyone else  has had this issue or any ideas what may cause this??
Mk6 GTI DSG
MK7.5 GTI performance DSG
Mk8 GTI
Offline symonh2000
« Reply #22 on: 01 April 2024, 10:28 »
I have had this issue on Goodyears and Dunlops recently, the goodyears were only 18 months old when they started showing signs of cracks down the middle of the main water channels (largely shielded from UV light)
I am told it is down to modern rubber compounds and a lot of high performance tyres suffer from it.
The Pzero on our GTI seem fine though and they are 4 years old.
Golf GTI 7 PP
BMW M140i
Offline davo245
« Reply #23 on: 01 April 2024, 11:55 »
Wonder if it could be caused by certain wheel or tyre cleaning products or tyre dressings?
Mk6 GTI DSG
Mk8 GTI
Offline joe6
« Reply #24 on: 01 April 2024, 13:46 »
The tyre fitter I use says that he sees more Goodyear and Dunlop tyres develop sawtooth issues than other manufacturers. Just started to develop on my mk6 with Dunlops fitted.
Offline symonh2000
« Reply #25 on: 01 April 2024, 18:44 »
Not sure, those things are not normally used on the tread areas.
Golf GTI 7 PP
BMW M140i
Offline davo245
« Reply #26 on: 10 April 2024, 11:28 »
Just mean the shoulder youcan see on pics where dressing has possibly been used.
Would this fail an MOT.?
« Last Edit: 10 April 2024, 17:26 by davo245 »
Mk6 GTI DSG
Mk8 GTI
Offline Al1040
« Reply #27 on: 10 April 2024, 12:22 »
AFAIK At this time, unless you can see through to the carcass it is not considered to be an MoT failure
67 Plate Mk 7.5 GTD DSG
Offline karlos
« Reply #28 on: 10 April 2024, 15:28 »
FWIW I'm having one of my rear Michelin PS4 replaced on Monday. Despite it still having over 3mm tread it's nearly 7 years old, has micro cracks, a sawtooth pattern on the inner shoulder and it's getting noisy like a worn wheel bearing. Not taking a chance as I'm doing a continental road trip next month.
I should really swap the tyres between front and back once a year to even out the wear.
2017 (67) GTI PP DSG. Tungsten Silver with DCC, Art Velours, Dynaudio, Climate Screen, Tints, Keyless, Rear Camera, Lane Assist, Seville wheels.
Offline Gulfstream11
« Reply #29 on: 11 April 2024, 08:06 »
Happened to me way back. I incorrectly mixed a cleaning product I used for the wheels. Tyres ended up scrap. I still use it, correctly mixed and no issues since. Tyres were Goodyear Assy's.
Previous rides..MKIV 1.8T   MKIV PD150  MK5 GTI MK5 edition30 now MK7 GTI PP
