Author Topic: Can you use OBDeleven to tell how often the VAQ has engaged?  (Read 10186 times)
Offline Rudedog
Re: Can you use OBDeleven to tell how often the VAQ has engaged?
« Reply #10 on: 03 November 2021, 12:44 »
As far as I know all wet-clutch DSG's are 40K, I wouldn't let it go longer as potentially you'll see issues and it's not that expensive compared to a new mechatronics unit!
Offline willni
« Reply #11 on: 03 November 2021, 13:19 »
Depends on the gearbox revision. Briskoda had this discussion with gearboxes.
https://www.briskoda.net/forums/topic/482244-dq381-service-intervals/
and with regard to the VAQ Diff, AwesomeGTI recommend 20k if you're an aggressive driver or 30k miles if you're normal. Interesting they don't specify a time interval, but given most of us will be doing around 6-10k miles a year, you could probably say 3/4 years.
https://www.awesomegti.com/haldex-vaq-front-differential-service-kit/
« Last Edit: 03 November 2021, 13:26 by willni »
Offline Rudedog
« Reply #12 on: 03 November 2021, 15:38 »
This is all interesting....
So we have the DQ381 fitted to the PP's, by the looks of things it's 80K and 'fluid only' and this box uses a different part number fluid to all of the others.
Oddly you would have thought that it should be the other way around and the 'hard' driven cars would have the shorter service time.
Having had a DSG in my previous Mk5 for 14 years I was used to a service every 40K!
To me this just highlights the downside of not having a physical handbook anymore listing the schedules, I guess I'll ask at my year three service next March.
Offline Coolhandluke
« Reply #13 on: 03 November 2021, 16:35 »
Like you I was used to having the DSG serviced  every 40,000 in my MK5 so was surprised when the dealer mentioned it was 80,000 in my PP.
If that's what they are saying I'll probably go with that.
Offline willni
« Reply #14 on: 03 November 2021, 20:04 »
Even a digital handbook in the car through the radio would be handier like those in modern BMW/Minis that tell you oil, coolant, brake fluid and brake pad life expectancy.
Rather than one you have to go to a dealership and get printed off
Offline Yusee
« Reply #15 on: 03 November 2021, 20:48 »
I would think usage/ mileage much more important than time. These oils don’t degrade over time.
Offline fredgroves
« Reply #16 on: 03 November 2021, 20:57 »
It's on the mk8...
Offline Yusee
« Reply #17 on: 03 November 2021, 20:58 »
I would. Essentially they’re either saying that
-It’s very unlikely to fail ( and experience has shown that, so let’s increase the service interval)
Or
-Changing the oil makes no difference to whether it does or not.
Interestingly, my 1988 205 GTi service handbook states , for gearbox oil - “ no oil change “
They probably didn’t expect the car to survive 30 years when they wrote that handbook, so I changed the oil last year!
Offline willni
« Reply #18 on: 03 November 2021, 21:36 »
Saw a post earlier on that said "Volkswagen state a 30k/3 year service interval for the VAQ diff", if I find it again I'll post it.
It's on the mk8...
Never mind if we have to forgo buttons for a car based service book, I'll buy a ring binder  :grin:
Offline joe6
« Reply #19 on: 03 November 2021, 22:38 »
Vwvortex site has a quote from a vw maintenance manual from 2015 stating 3 years for gti pp but I agree with you that mileage is probably more important and type of usage.
