Author Topic: What have you bought for your Mk8?  (Read 144184 times)
Offline Sean G
Re: What have you bought for your Mk8?
« Reply #290 on: 07 July 2022, 11:12 »
New wheels and tyres as pictured for the Edition 45 will be fitted before collection
Will have the full front end PPF’d including the mirrors and the B pillars wii also be done
The car also getting a full ceramic coating including wheels, brake callipers and glass
ACF 50 applied to the underside
Will have the R paddles fitted and front and rear dash cameras
EZ visor delete decals and sill protectors fitted along with inner cill Edition 45 metal plates for the inner plastic cills
Warning triangle and load liner and mud-flaps and the Ali express footrest also to go on
The arch winglets are being removed
Looking forward to collection in a few weeks and then time to enjoy it
Offline fredgroves
« Reply #291 on: 07 July 2022, 11:42 »
Has anyone found someone who makes an infill piece to go in the bloody big hole under the rear bumper?
I don't care if its just black ABS, just worried that it will fill with crap and rust the car body
Offline Ceefeesh
« Reply #292 on: 07 July 2022, 13:00 »
That’s quite a list. I have done most of those changes but not all. You’re particular and will have the car how you want it. Why not? Enjoy.
What are your wheels? They look very nice.
« Last Edit: 07 July 2022, 13:15 by Ceefeesh »
Offline Sean G
« Reply #293 on: 07 July 2022, 13:36 »
Probably too particular but it’s worth the hassle to have the car the way I want it
Still deliberating in fitting a set of Eibach springs but will wait and see how it sits with the wheels fitted
The wheels have just been released recently
Veeman VC580R
https://www.veemann.com/
Here’s a pic on MK8 R
Offline DB99
« Reply #294 on: 07 July 2022, 15:03 »
Will be interested to see the wheels on the CS45. Quite like the look of them.
Offline Ceefeesh
« Reply #295 on: 07 July 2022, 20:09 »
What about an easer option? A Skoda washer bottle ‘funnel cap’?  :laugh:
« Last Edit: 07 July 2022, 20:13 by Ceefeesh »
Offline Sean G
« Reply #296 on: 07 July 2022, 22:51 »
😂😂 think I’ll give that one a miss !
Offline RoryB
« Reply #297 on: 08 July 2022, 13:30 »
Yes, they’re the R paddles. No, you only need to remove the airbag (basically the centre piece of the wheel where you press the horn). This pops off quite easily, you just need to release 3 clips on the back of the wheel. Once you’ve that off you need to gently prise off the silver trim, it’s just clipped in. Once that’s off, the existing paddles are easily removed by undoing a Torx screw for each one and disconnecting them. The new paddles fit in exactly the same way.
Oh, other thing we did is remove the fuse for the horn. It kept going off and nearly giving us heart attacks / temporary deafness when removing the airbag!
Everything went back together 100% and no dash errors. I’d say it took about 20-25 mins.
Volkswizard has a video on it.
Joe, did you have to disconnect battery or anything? I have mine sitting in the car since I got it afraid to do it in case I mess something up
No, no need to disconnect the battery but I would recommend removing the fuse for the horn as it’ll keep going off!
Definitely disconnect the horn. One accidental blast is enough to convince you. I had literally no idea what I was doing. Some great help from people on here as always. Once you’ve removed one clip it becomes much easier as you know what to do.
Tbh fitting the dynamic indicators was harder.
On and don’t touch the start button by accident unless you want the airbag warning light to stay on! Yes, I’m a total pleb.
Good luck!!!
Job done, getting the airbag off was the most difficult part, I was able to leave it plugged in. Good call on the fuse for the horn 😃
Gone: Mk 5 GT Sport 140
Sticking around: Mk 7 GTD
Current: Mk 8 GTI Clubsport
Offline king monkey
« Reply #298 on: 08 July 2022, 15:26 »
Great job! Having those R paddles fitted has made me use them more than I ever have in previous cars. Enjoy!
Offline carlt69
« Reply #299 on: 10 July 2022, 22:43 »
After washing it I’ve just booked it in for a valet and ceramic coat.
It’s the first time I’ve ever ever paid for anything like this on my cars so I’m hoping it’s worth it  :grin:
MK8 GTi in Moonstone Grey
