Author Topic: Squeaky/creaking door or window rubber seals?  (Read 10159 times)
Offline scottdaryll89
« on: 12 August 2021, 20:21 »
Had my GTi since March and it has now started creaking from the door seal area, I’m not sure if it is something I have used to clean my car with and will go or it will keep creaking? Has anyone else had this ?
Offline fredgroves
Re: Squeaky/creaking door or window rubber seals?
« Reply #1 on: 12 August 2021, 20:30 »
I've got a creaking noise that seems to be the plastic panel on the opening edge of the door, that strip by the window.
It's very annoying.
They've tried to fix it but no luck. It's worse when it's sunny.. Being a dark plastic piece it's probably thermal expansion somehow.
Offline Wrex22
« Reply #2 on: 12 August 2021, 20:43 »
My drivers door does this, but not all the time. Sure it sounded like it was glass creaking today
Offline fredgroves
« Reply #3 on: 12 August 2021, 21:23 »
I'm sure it's that exterior trim panel...
« Reply #4 on: 12 August 2021, 22:51 »
Do you mean the black one with the the Volkswagen on the bottom? Is so that creaks on mine too but I’m more saying like the door rubber seals when you go over bumps etc
Offline SRGTD
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline Jason27
« Reply #6 on: 13 August 2021, 08:26 »
Have had this on and off definitely worse in hot weather think it’s both black B pillar trim and door seals !!! Very loud some days going over speed bumps slow ... can’t believe for a car that handles so well it’s due to chassis flex or stiffer suspension  ???  Treating the seals seems  a great first step I have rubber seal lubricant in a spray can for my caravan toilet  :grin: :grin: :grin: will try that let you know
Offline SRGTD
« Reply #7 on: 13 August 2021, 08:36 »
I had squeaky door seals on four of the five VW’s I’ve owned (current car is still squeak free). The door seals do dry out over time, and certain car cleaning products can speed up the drying out process.
Treating the seals periodically with a lubricant such as Krytox or Gummi Pfledge usually works and stops them creaking. Krytox is very expensive, but a little goes a very long way and the effects last a long time. Gummy Pledge is much cheaper but not as durable as Krytox, so the seals may need more regular treatment.
Offline fredgroves
« Reply #8 on: 13 August 2021, 10:15 »
Yes its that trim.
And it doesn't do it when its cold/wet....
Offline Adam T7
« Reply #9 on: 13 August 2021, 15:37 »
I have the same on my 7.5, Gummi pffledge stops it for a while.
I had the same issue on a new 3 Series years ago - technician who swapped the seal told me wash and wax accelerates the seals drying out.
I think I’ll invest in some Krynox.
