Author Topic: Fitting damptronic to a passive car ? Advice needed  (Read 3236 times)
Offline Pete-r36
« on: 12 August 2021, 01:57 »
Hi folks, can you fit aftermarket damptronic to a passive car?
My 7.5 GTI is on passive shocks, 18” Parker wheels and Potenza tyres but the roads where I live are really poor and the ride is too firm for my liking.
Would a tyre swap help, or could I fit aftermarket active suspension (KW, B16 etc) with a separate control? And if so, does anyone know how these systems in their comfort settings compare to passive?
Thanks.
Offline baka
Re: Fitting damptronic to a passive car ? Advice needed
« Reply #1 on: 12 August 2021, 02:12 »
I had the same issue and fixed it by going down to 17's. That's obviously not to everyone's taste though.
Offline mcmaddy
« Reply #2 on: 12 August 2021, 07:59 »
You could try changing to Michelin PS4 tyres first as they are really soft on the sidewalls compared to the factory Bridgestones.
Offline Pete-r36
« Reply #3 on: 12 August 2021, 17:38 »
Thanks for the replies, I think the potenzas are pretty rubbish all round so a swap to PS4 would be a win win and might try that. I think lighter wheels might also help to get the unstrung mass down.
Not seen a 7.5 GTI  on 17, but I used to run my mk5 on 16s in winter and it was lovely. I’m guessing it’s tight on the performance front calliper?
Offline willni
« Reply #4 on: 12 August 2021, 18:05 »
You could also change the tyres to slightly wider or a higher profile 225/40R18 being standard, 235/40R18 (-1.24% Speedo error so when showing 70mph it's actually 69.132mph) or 225/45R18 (-3.41% Speedo error when showing 70mph it's actually 67.613mph).
Offline baka
« Reply #5 on: 12 August 2021, 20:05 »
I'm running factory 17's from the GTI in a bunch of other markets, so no clearance issues. I think most OEM 17's and aftermarket wheels in the right fitment are ok.
I went to PS4's at the same time but not from the original Flintstones so can't really comment, other than a lot of people have said they ride like crap and Michelin's are a improvement.
These wheels but not  my car.
Offline fredgroves
« Reply #6 on: 12 August 2021, 21:42 »
Seventeens and light as possible alloys is the answer.
Seventeens are perfectly OK, in Germany they are standard fitment.
