Author Topic: OBD11/VCDS Tweakery  (Read 30884 times)
Offline monkeyhanger
OBD11/VCDS Tweakery
« on: 11 August 2021, 14:26 »
Hi everyone. Still loving the ID3 and an £18pm fuel bill between 2 cars.. :whistle:
Anyway, there's not much OBD11 action on the ID3, everyone with the first software iterations had a poke around and were scared to alter anything. I decided to have a poke around today as i'm on 2.1 rather than 1 which had all the issues (similar to the MK8 Golf presumably).
My pet hate is lane assist. The twitch of the steering wheel back towards a parked car that you've gone wide to drive past is really unnerving, and if you can't keep within a lane then you really need to put the F'n phone down and stop texting on the move! I found a setting within the assistance systems module to make the car remember last setting, rather than the car putting it back on every ignition cycle by default - and it works.
Anyone here done any MK8 tweaks yet? Presumably they're on broadly similar module architecture so what works on one should work for the other?
Offline fredgroves
Re: OBD11/VCDS Tweakery
« Reply #1 on: 11 August 2021, 15:48 »
That sounds interesting.... I thought the lane assist setting was in the SFD protected bit - or at least on the Golf. What did you set?
The only thing I've done is turn on the exit warning system, which is disabled on my GTI for some reason - the later ones its not.
Much of what you will want to tweak however will be in the SFD protected controllers...
« Reply #2 on: 11 August 2021, 16:25 »
After a kick up the derrière from Massimo a few months ago I dug out my trusty old VCDS cable to confirm the expected - it was too old to work with the mk8 generation ECUs.
I must get round to eBaying the thing one day as it’s the old unlimited VIN cables.
I’d not seen anything mentioned on here to inspire me to purchase a more up to date cable.
Good to hear you’re still enjoying the ID MH. Have you done your old marker post performance test as a comparison to your old GTD and R yet?
« Reply #3 on: 11 August 2021, 21:16 »
Just pulled from my post on the EV forum:-
How to have lane assist remember what it was last set to e.g. leave it off unless you want it on:-
Control Unit>A5 Assistance systems>configuration for lane departure warning>change "active" to "last setting" then ok>press and hold green tick to save it.
The mirror settings is on a toggle switch that cycles a light to each setting, but annoyingly, the car always forgets you left it on "L" last ignition cycle, so you have to remember to put it to L every journey if you want mirror dip on reverse ' is the MK8 like that or is there a physical switch like MK7 and everything before where you can see it physically set to L?
Anyway, it's annoying it forgets L for mirror dip. There are 3 settings in drivers door controller that look as though they would either make mirror dip on reverse or make the car remember last mirror settings:-
1 = memory mirror
2 = mirror lowering with rear gear
3 = position memory with rear gear
Neither one on its own or a combination of 2 or 3 of them seem to work.
There was a rumour that the difference between those with 2 zone climate and those with 1 zone is purely software on the ID3. Our Life has 1 zone and our Family spec has 2 zone. Set Life up as Family in aircon controller and still operating as 1 zone.
Activating travel assist asks for a 5 digit code.
My biggest annoyance - lane assist coming back every ignition cycle, is resolved, so that's a win for me.
« Last Edit: 11 August 2021, 21:18 by monkeyhanger »
« Reply #4 on: 11 August 2021, 21:26 »
Haven't done the marker test yet, I'm hardly ever up that way since some bright spark decided to remove the roundabout that allowed traffic to flow freely and replace it with a cross roads that makes my turn in a 3 minute wait on the lights cycle - genius!
My expectations are that it'll be somewhere between my old GTD and the Polo GTI. I'd say it's marginally slower than the Polo on a rolling start,but would kill it from a standstill (no tramping and phenomenal 0-30mph acceleration, like most EVs. The instant torque at any time (never in the wrong gear) is great, even if there's faster cars on the road
Offline fredgroves
« Reply #5 on: 11 August 2021, 21:35 »
The mirror switch on the mk8 is an actual switch... One of the few!
I'll have a look at the lane assist tweak tommor. I don't think it will work but...
« Reply #6 on: 11 August 2021, 21:44 »
After the tweak, don't forget to actually turn  lane assist off to see if it stays off.
Offline ajmoir36
« Reply #7 on: 11 August 2021, 23:28 »
My dad is collecting a Mk4 Octy VRS Monday and one of the items listed on there was making the lane assist remember it’s settings. I know it will be set on my mk8 R when I get it. I upgraded my VCDS to one of the newer HEXNET wireless unlimited dongles as my old HEXCAN USB didn’t fully work with my 7.5 R 2019. It does the same as it used to except the firmware in the dongle can be changed. So far there is a VCDS beta out to access the SFP modules if you have a token. Just where do we get the tokens?
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
Offline fredgroves
« Reply #8 on: 12 August 2021, 08:14 »
The tokens...you need to generate one from the vw geko system.
Basically you can't.
Read my post about sfd on here for more information...
« Reply #9 on: 12 August 2021, 13:49 »
I'm surprised this approach doesn't bring VW under scrutiny for anti-competition/consumer EU regulations. Once these cars go out of warranty, if you have need of a repair that's software based, you'll be at the mercy of the dealerships rather than going to your local independent VAG specialist garage. I thought the EU would be all over that.
