Author Topic: Gas bonnet strut anyone?  (Read 16791 times)
Offline Watts
Re: Gas bonnet strut anyone?
« Reply #10 on: 07 July 2021, 19:22 »
I've only opened the bonnet on my MK7.5 twice since I've had it and that's to top up the washer fluid, my engineering skills end there.
So if you're not going to use it, why are you bothered?
I didn't say I was bothered but why are you bothered that I might be bothered?
Now you've mentioned it; I'd be bothered for the forty thousand pound cost and the the fact that the part has got the necessary infrastructure in place to put a gas strut in place instead of substituting it for a cheaper alternative but honestly I'm not bothered now I've thought even more about it.
Have a nice day. :smiley:
Re-read your own post, I didn't quote it all but it does come across as being bothered about it! I'm not bothered as to whether or not you are bothered but I bothered to ask why your seemed bothered :laugh:
Previously:
Offline Talk-torque
« Reply #11 on: 07 July 2021, 21:33 »
If you watch the video while the guy is closing the bonnet after completing the install, you can see that the strut is going to end up clashing with the coolant header tank. VW possibly raised the design position of the header tank after the gas strut was deleted. The gas strut is flexible enough to bend over the header tank, but that bending will cause it to fail quickly and it will be rubbing the header tank which may result in a leak.
A bit more research needed on this mod!
Roger.
Offline massimo23
« Reply #12 on: 08 July 2021, 00:16 »
I was messing with this for a few days and I asked myself is it really worth the hassle to install this when I open the bonnet a couple times a year? Then what if something gets damaged? What about the insurance, could this cause problems if you had a frontal accident? Remember the crash tests have been done without the gas strut. So I went with option Forget about it :laugh:
Offline valentino
« Reply #13 on: 13 August 2021, 18:11 »
Has any one fitted a gas strut without the complication of the compromise on the  coolant tank?
Offline ajmoir36
« Reply #14 on: 14 August 2021, 01:06 »
There are a few people on vwroc that have done it. Not sure if it’s the same.
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
Offline valentino
« Reply #15 on: 14 August 2021, 12:11 »
Kristian Kassinen <sales@darkicedesigns.com>
Fri 13/08/2021 20:18
Hi,
The kit used to touch the top of the coolant tank. We now have a spacer block they moves the strut away from the coolant tank.  If anyone has an original kit please can you let them know to get in touch with us and we will send out a spacer to them :)
Thanks,
Kristian
Team @ Dark Ice Designs mobile
Offline king monkey
« Reply #16 on: 14 August 2021, 12:50 »
This is good to know. Thanks for posting.
Offline fredgroves
« Reply #17 on: 14 August 2021, 21:45 »
Isn't the coolant tank on the other side on the clubby? Seem to remember that from the volkswizard video about the gti vs the clubby.
« Reply #18 on: 15 August 2021, 08:41 »
The Clubsport and the R are on opposite sides I think(?)
I’m sure the Clubsport and S3 share a similar layout but the R is different. Can’t quite remember now, my memory is getting shaky! Funny, I can remember detail differences on mk2 Golfs from 30 years ago but can’t remember anything recent  :grin:
Offline king monkey
« Reply #19 on: 15 August 2021, 09:06 »
That makes sense as there’s been no problems reported on there about fitting.
