Author Topic: Clutch pedal stuck to the floor  (Read 15309 times)
Offline madstaff
Re: Clutch pedal stuck to the floor
« Reply #10 on: 27 June 2021, 12:18 »
If the pedal is nice and firm, not really, good practice to bleed but if your not sure what your doing could end up with no pedal at all.
Must be a reason though why it's used some fluid??
Have you found the cause of the fluid under the airbox??
Offline Oilslick
« Reply #11 on: 28 June 2021, 21:53 »
No, can’t find the cause this far.
Fluid remains to the top since I refilled, no signs of leaks.
The pedal was half way down today when I got in it today but flicked it up and pedal was firm, no issues since then
Offline jaceyboy
« Reply #12 on: 13 October 2022, 09:47 »
Did you get any repeat of this?, ours has done this today, pedal stuck and when lifting back up there is only small pressure, no pressure when going down, hope its just the slave cylinder thats gone.
MK7 GTi
Offline symonh2000
« Reply #13 on: 13 October 2022, 11:28 »
Doesn't it have a concentric slave?
If so the whole gearbox will need to come off, and whilst you are in there you may as well fit a new clutch.
I would be tempted to change the master first as it will be a much simpler job.
Golf GTI 7 PP
BMW M140i
Offline Adam T7
« Reply #14 on: 13 October 2022, 11:45 »
Get it checked, my wife kept complaining it was happening in her Polo, I couldn’t replicate the fault, but took it to local Indy (used loads of time). After examination, confirmed it was the slave so Gearbox out - got a new clutch at the same time due to mileage - seemed sensible.
« Last Edit: 14 October 2022, 17:06 by Adam T7 »
Offline jaceyboy
« Reply #15 on: 13 October 2022, 12:32 »
Ive topped up the brake fluid and the clutch is working again, seems I have a leak, and probably from the slave ffs, has anyone changed there clutch to an uprated one?, might as well as its mapped stage 1
MK7 GTi
Offline symonh2000
« Reply #16 on: 13 October 2022, 21:24 »
The person who invented concentric slave cylinders should be shot.
Who in their right mind would put a part like that in a place that requires the gearbox to be removed when it fails?
Golf GTI 7 PP
BMW M140i
Offline Adam T7
« Reply #17 on: 13 October 2022, 23:55 »
Shooting would be to quick.
Offline symonh2000
« Reply #18 on: 14 October 2022, 10:36 »
It depends where you shoot them.   :evil:
Golf GTI 7 PP
BMW M140i
Offline jaceyboy
« Reply #19 on: 14 October 2022, 14:28 »
Some crazy Krout, bloody stupid idea
MK7 GTi
