Author Topic: plastic part around key ignition badly scratched  (Read 5712 times)
Offline nunchuck
hi , going to replace the badly scratched plastic area around key ignition , maybe former owner had dimond ring on ?
anyway what is the part name of the pastic part so i can try and replace
thanks
2019 golf gti  pp
Offline Talk-torque
Re: plastic part around key ignition badly scratched
« Reply #1 on: 06 June 2021, 06:49 »
Remove the part and the number will be somewhere on the inside, moulded in.
To help you find it, the number should start with something like 5G0, or 5G1, followed by 2 groups of 3 numbers.
Roger.
Offline madstaff
« Reply #2 on: 06 June 2021, 09:09 »
I've always referred to these parts as the upper and lower steering column cowlings.
And yes, they will have a part number on, the last 2 digits are the colour code IIRC.
Offline nunchuck
« Reply #3 on: 06 June 2021, 09:25 »
thanks for your help, is this job difficult to do or would it best i take it to VW Dealer
thanks again
Offline nunchuck
« Reply #4 on: 06 June 2021, 09:26 »
thanks for your help.
Offline madstaff
« Reply #5 on: 06 June 2021, 09:59 »
No real knowledge of removing these on a MK7.5 golf, but normally there's 2 or 3 screws on the underside of the lower cowling to remove then then the upper and lower are held together by some retaining clips and should come apart with a bit of a pull.
Relatively easy to do.
Maybe have a look in the workshop manua, its in the repair section, body, body interior section, here https://www.golfgtiforum.co.uk/index.php?topic=287703.0
« Last Edit: 06 June 2021, 10:04 by madstaff »
Offline nunchuck
« Reply #6 on: 06 June 2021, 12:31 »
thanks will down load it when i get home from work , so just a quicky i wont have to remove the steering wheel
then ?
Offline madstaff
« Reply #7 on: 06 June 2021, 14:00 »
Not sure, looking in the manual it shows the steering wheel removed, but you may be able to access the screws without removing the wheel.
Screws could be accessible if you turn the steering wheel left or right??
Offline nunchuck
« Reply #8 on: 06 June 2021, 14:16 »
thanks  not getting car until wednesday  will take a look then
thanks for your very helpful input
Offline Vwjap
« Reply #9 on: 06 June 2021, 21:49 »
If it’s like the passat then there’s 3 torx (t25 I think) then 2 behind the steering wheel where the 2 bits of plastic meet (cowl)
Don’t need to take them off on the golf in my job but do on passat
