Author Topic: Fuel Flap Actuator  (Read 7305 times)
Offline Rob_benton
Re: Fuel Flap Actuator
« Reply #10 on: 29 May 2021, 18:30 »
I've just had a similar problem but my actuator has failed locked not open, as I discovered at the Shell station!  :angry:
Same happened to me. Just replace it for £30. Piece of mind it won’t happen again.
2014 gti pp dsg
Offline rwleigh
  • Richard.
« Reply #11 on: 29 May 2021, 20:11 »
Are you sure it's the actuator as wedging shut is quite common and it's a little bit of plastic that needs trimming. 1 minute job if it is.
Definitely not wedged shut, still moves the same as it always did when locked.
Golf GTI CS40 #010 | Manual | 5 door | Pure White | Car-Net | 90% tints | Winter Pack | REVO stage 1
Offline rwleigh
  • Richard.
« Reply #12 on: 29 May 2021, 20:12 »
I think I just need one of these.
https://www.ebay.co.uk/itm/324017468013?fits=Plat_Gen%3AMK+VII&hash=item4b70f2326d:g:B5MAAOSwD9Jd-2nV
Offline Rob_benton
« Reply #13 on: 30 May 2021, 20:30 »
Get a genuine one for roughly the same price so hopefully it’s reliable.
I don’t want to go through trying to unlock my flap again with 10 miles of fuel in the car.
2014 gti pp dsg
Offline rwleigh
  • Richard.
« Reply #14 on: 30 May 2021, 20:47 »
How did you open it, I have 75 miles range left and it's booked in at my preferred independent on Tuesday for an oil change anyway so will ask them. No doubt they've seen it before.
Offline Rob_benton
« Reply #15 on: 31 May 2021, 16:25 »
[/quote
Keep pushing the flap to open it while opening and locking the car on your keep fob a number of times.
Only other option I’ve heard is forcing the flap open and I don’t fancy that.
2014 gti pp dsg
Offline rwleigh
  • Richard.
« Reply #16 on: 31 May 2021, 18:33 »
I've tried that with no success, like you I don't fancy forcing it.
Hope to get it sorted tomorrow...
Offline Rob_benton
« Reply #17 on: 31 May 2021, 21:09 »
I can’t remember if you can unlock the flap by simply just removing the actuator from inside the boot thinking about it.
2014 gti pp dsg
Offline rwleigh
  • Richard.
« Reply #18 on: 01 June 2021, 19:52 »
So finally today while in for an oil and filter at my local VW specialist the technician managed to get my fuel flap open. Actuator failed completely and a new one ordered. It was a major fight for him to get it open, no way I would have done it at the petrol station.
Remember folks, make sure you keep your flaps clean and lubricated!  :wink:
