Author Topic: Stop start stopped  (Read 13788 times)
Offline Carbon VW
Re: Stop start stopped
« Reply #30 on: 10 May 2021, 12:33 »
Invest in a battery tester which will test the battery on load. I suspect your problems will be solved by getting a new one and coding it in for stop start. (or coding the stop/start out which is what I did)
Is it possible to code the car such that S/S is off by default, but can be turned on with the button? The opposite of the standard setup?
Or is it a case of you can only code it out completely?
I have  the Pro Version and I coded it out completely with an APP within the software. It can also be done manually in the adaptations. Basically, you are fooling the car into thinking it doesnt meet the requirements for stop/start to be available.
AFAIK, (open to corection), you cannot code it so that it can be turned on with the button but defaulted to off.
Mk7 CSG GTi 6MF Stage 1, CSS backbox
Offline Watts
« Reply #31 on: 10 May 2021, 13:31 »
Iirc, I read somewhere that there is a cable that goes to the battery that if disconnected will disable stop/start. Worth a search/google.
Personally I like it on and only rarely switch it off. Also the fact that it is effectively a warning for a low battery.
Previously:
Offline Carbon VW
« Reply #32 on: 10 May 2021, 13:50 »
You are correct Watts thats the battery monitoring module. Each to their own, i cant stand STOP/START. the poor battery and starter motor!!
Offline joe6
« Reply #33 on: 19 May 2021, 07:53 »
My stop start is not working on a 22 month old car just bought. Mileage suggests lengthy time unused. Dealer said it would work after the battery had a good charge. Not happened. Voltage is 12 .2v. Is this low enough to stop it working? Since battery warranty is 2 years wondered if dealer would replace it? Thoughts welcome.
Offline davo245
« Reply #34 on: 19 May 2021, 12:21 »
Dealer replaced my battery just under 3 years old when my start stop was intermittent. Works fine now.
Mk6 GTI DSG
MK7.5 GTI performance DSG
Mk8 GTI
Offline Refurbished.
« Reply #35 on: 19 May 2021, 17:34 »
Update - battery changed and coded. Has made zero difference. No error codes but no stop/start.
Offline fredgroves
« Reply #36 on: 19 May 2021, 17:39 »
Do you get the message about stop start pop up on the MIB?
And the A with a line through it?
If you do get it on the Mib, press the "i" button and you can see why its not stopping... might need to be on the vehicle status screen to see it.
Offline Lordie
« Reply #37 on: 19 May 2021, 18:21 »
Aren't batteries like this designed to run with stop/start? I imagine the starter motor too? So surely it won't do any harm as that's what they're made to do and they're not the same as on a standard car without it
Offline fredgroves
Offline Lordie
« Reply #39 on: 19 May 2021, 20:51 »
https://www.rac.co.uk/drive/advice/road-safety/stop-start-engines-and-engine-idling-the-law/
Thanks! That's actually a good read and clears a few things up. Personally I like the stop/start and impressed by how flawlessly it works ....just a shame that mines still stopped working for some reason :grin::grin: ffs
