Author Topic: Harman Kardon vs Standard Equipment  (Read 38747 times)
Offline massimo23
Re: Harman Kardon vs Standard Equipment
« Reply #30 on: 26 April 2021, 14:23 »
The sub is definitely in the boot, not sure about any amp. Suspect it probably is under the seat though, not looked.
What Exonian is looking for though is where the "stereo" unit is in the car, to see if it has a port for a sub to plug into and if its the same interface as the Mk7 to connect a Helix plug and play sub into it.
Yes the Sub [8]  is in the boot (Spare wheel) and the Amp [10] is also in the boot (Left side wall)
Offline fredgroves
« Reply #31 on: 08 June 2021, 10:50 »
Just thought I'd loop back to this subject as yeterday I made some interesting discoveries.
Up until yesterday, I'd tried a few different audio options...
1) Bluetooth - its terrible
2) Music on a USB stick - its not great
Now #1 I expected, #2 was how I ran my Mk7/7.5's and it was fine with the caveat that your audio files need to be suitably good enough.... only I've been dissapointed - even after I sought lossless FLAC files of my favourity tunes.
Yesterday on my road trip I thought I'd try messing with Alexa again. It actually worked for once, which in itself is a minor miracle but...
The music via Amazon is loud, its got base it totally blasted me, I couldn't turn it up to max, it was totally shaking me! Brilliant!
THAT was what I was expecting HK to do (no distortions either), but I don't really understand why.
It has to be the audio codec on the MIB unit.... I can only assume the Alexa app has its own.
Anyway, tip for anyone wanting to shake plaster off of the walls of houses you drive past.... use Alexa (if you can make it work!)
Offline Dav3smith
« Reply #32 on: 08 June 2021, 11:15 »
Thanks Fred, that's good to know as I've specced it.
I knew it must have some benefit over the standard kit and I'm relieved you've used some witchcraft to finally unleash its potential.
GTI Clubsport ED45 DBP, DCC, HK, WP, Pano
Gone Golf R 7.5
Gone GTI 7
Offline fredgroves
« Reply #33 on: 09 June 2021, 10:43 »
You might also discover that even standard audio benefits from this tip too...
The audio codec is the same on the MIB unit....
It pains me though to have to say you need to use Alexa and Amazon though.
Even through Android Auto or Apple Car play you don't get the same effect. That too must be using some sort of interface to the standard audio processing.
Offline Boothy1979
« Reply #34 on: 03 July 2021, 01:06 »
I have just got my MK8 GTI and had no choice with extras as it was already built. Given the chance I would have put the HK on as I have come from a new shape focus with the B&O which I have to say was out of this world for sound quality. So I was a little concerned I would be disappointed with the standard system. I have to say I am really pleased with it. I play all my music wirelessly via Apple music and it sounds great. Don't get me wrong, its not out of this world but it is good enough for me to maybe not consider any upgrades but I have not had it long, so could change my mind.
Current car: Manual MK8 GTI 245, Deep black pearl.
Ordered: DSG MK8 Clubsport, DCC, Pure white.
Offline Dogman12
« Reply #35 on: 03 June 2025, 08:01 »
Hi guys! All in all, does stock (6+1) sound system sound enough in the 8/8.5 GTI/R ?
Offline DrG_GTi
« Reply #36 on: 04 June 2025, 10:30 »
Personally, yes i think it does. I like my bass and my taste in music is stuck in the 90's for house, trance, dance and so on and i have had my fair share of audio upgrades, subs etc in the past.... and it pleases me once you have the equaliser tweaked to your ears.
Some radio stations must transmit with rubbish flat bass, or cheaper codecs etc, but Spotify via AA is perfect.
2021 Mk8 GTI Clubsport - Reflex Silver
Offline Tarmac_Terrorist
« Reply #37 on: 04 June 2025, 13:18 »
I’m pleased with the upgraded sound system - better than the Sonos I had in my 2022 RSQ3. Bass is decent but won’t necessarily rattle the ornaments on your neighbours mantle piece
Offline Dogman12
« Reply #38 on: 04 June 2025, 17:41 »
Thanks for your feedback! I use Apple Music via Apple CarPlay. Not sure how that will sound.
Offline BikeSausage
« Reply #39 on: 30 June 2025, 20:04 »
Really interesting to read the comparison of HK over standard.
My dearly departed 2022 Volvo had HK as standard and it was chuffing brilliant. But for some reason that I cannot recall, I didn’t spec on my new Golf. Maybe because I was so distracted by the driving experience vs a Volvo estate that I forgot to properly evaluate the stereo.
Before I picked the car up I was worried. But within 5 minutes of driving away, I was reassured. The standard system is “good enough”. I’m sure the HK option is noticeably better but I’m OK with what I have. Pleasantly surprised.
Mk8.5 GTI
Kings Red Metallic
DCC
19” Queesntowns
Area View
Spare wheel
Electric Tow bar
