Shell is 100% identical, only diff is what bits are bolted to it
Ideally you want to get a late spec (post 90, hazard switch on the column) as then MK3/Corrado/Passat engines/dash clocks etc will plug straight in as the fuseboxes are the same. Doesn't matter too much either way, but it just makes it slightly easier
