Author Topic: OBDeleven scan - software version checking  (Read 11036 times)
Offline massimo23
Re: OBDeleven scan - software version checking
« Reply #10 on: 26 April 2021, 13:38 »
If you have the side assist we are also missing a feature available on the newer built cars: Exit warning system.
Well I managed to activate this function and I actually find it useful, Here is a short video of it in action:
https://youtu.be/I_lmFqvpEUI
Offline fredgroves
« Reply #11 on: 26 April 2021, 13:39 »
No, I don't have map in dash  :angry:
Have you ever found out why the change in BW48 to the newer unit D?
It doesn't align with a MY change...
I've still got an argument in mid flight with VW UK that I've not posted about on here, but will do as soon as I get some sensible answers, at the moment its still brewing  :whistle:
Offline fredgroves
« Reply #12 on: 26 April 2021, 13:40 »
Oh! That's damn good!
How did you manage to code it and how on earth did you overcome SFD to do it?
Offline massimo23
« Reply #13 on: 26 April 2021, 13:48 »
well I know how to activate the maps on the dashboard but you need to unlock the 5F control unit and then code with either Vcds or OBD11.
Only some of the control units are Sfd protected like the Brakes, Central Electrics, Gateway, Infotainment and Part of the dashboard.
Offline massimo23
« Reply #14 on: 26 April 2021, 13:51 »
Check here for the dashboard: https://forum.obdeleven.com/post/49306/thread
I see you have the HUD. Is the laptimer visualised on the HUD also?
Offline fredgroves
« Reply #15 on: 26 April 2021, 14:21 »
I've never tried the laptimer....can try it later if you like.
Offline massimo23
« Reply #16 on: 26 April 2021, 14:59 »
Thats no problem. I see there is a setting in the long coding of the HUD to enable it.
