Author Topic: Clusters too dim  (Read 3891 times)
Offline fredgroves
Re: Clusters too dim
« Reply #10 on: 23 February 2021, 14:54 »
Maybe the light sensor has started to go HR?
Alternatively, can you look at someone else's car and see if the levels are any different? It could just be your expectations are not what the car does...
Offline K9golf
« Reply #11 on: 23 February 2021, 16:04 »
It’s so dim you can barely tell if lights are lit
Offline fredgroves
« Reply #12 on: 23 February 2021, 16:40 »
I suspect the light sensor has gone crazy...
Offline K9golf
« Reply #13 on: 23 February 2021, 16:44 »
The light sensor? You referring to the sensor next to the 7 on the dial?
Offline fredgroves
« Reply #14 on: 23 February 2021, 17:05 »
If that is what seems to effect it, either covering it or shining light on it.... sounds like the levels of light its reporting are wrong.
Offline K9golf
« Reply #15 on: 23 February 2021, 17:11 »
It must be the sensor playing up
Offline Lordie
« Reply #16 on: 23 February 2021, 18:18 »
I have a 2014 if you need any pictures from mine?
Don't really use the dials much, I set the screen in the middle to show my speed the day I picked the car up and I've never changed it  :grin:
