Author Topic: It’s all about the bass...  (Read 48977 times)
Offline Carlosfandango
Re: It’s all about the bass...
« Reply #30 on: 15 March 2025, 05:15 »
Might be worth looking at an oem hk retrofit...
There are kits available on AliExpress but they are pricey, the install shouldn’t be too bad, but there may be a fair bit of dismantling involved, particularly the door panels , speakers and associated wiring, but having said that, once started it may not be that bad, I once retrofitted HID headlights with AFS to one of my Mk6 GTIs, I fitted everything exactly as would have been done in factory, it was a big job, but not too difficult, I think the HK install would probably be similar in terms of difficulty levels, although the kit on AliExpress has the rear tweeters, they would need fitting in to the rear doors, this may be difficult, so new rear door panels with the tweeter grills already in them may be needed in order to make life easier, for a competent installer/DIYer it could actually be a relatively easy and satisfying upgrade, it would then just need OBD11 or VCDS to code it.
VW Golf 8 Harman Kardon Full Kit Car Audio Upgrade - Premium Sound System Installation Bundle
https://a.aliexpress.com/_EQoi4vQ
« Last Edit: 15 March 2025, 05:22 by Carlosfandango »
Current -
Gone -
2022 Mk8 GTI DSG, Kings Red.
2003 Mk4 R32, Reflex Silver.
1991 AX GT.
1984 Mk1 XR2.
Plus many more.
Offline GE90
« Reply #31 on: 15 March 2025, 08:25 »
Yep, considering that, but need door cards too, so would require a complete strip of a source car.
If something comes up, I’ll be very interested.
Cheers.
Offline fredgroves
« Reply #32 on: 15 March 2025, 09:08 »
Pricy? That's hundred and fifty quid...
« Reply #33 on: 15 March 2025, 21:46 »
Unfortunately not, have another look, that is for the A pillar tweeters ONLY, there are two options to choose before checkout, the full kit is £1500.
Current -
Gone -
1991 AX GT.
1984 Mk1 XR2.
Plus many more.
Offline fredgroves
« Reply #34 on: 15 March 2025, 23:00 »
Ahhh classic Ali bait and switch
Offline GE90
« Reply #35 on: 03 September 2025, 07:23 »
Hi all
I’ve fitted the MK7 Helix kit to my non-HK MK8, but while it works perfectly for a few seconds, the door speakers then shut down, leaving just dash speaker working!
Any thoughts appreciated.
