Author Topic: We Connect App  (Read 5361 times)
Offline mistac
Re: We Connect App
« Reply #10 on: 22 January 2021, 20:28 »
I have it set up on my 20 plate 7.5 GTI (but rarely use it) - once the app is installed and user a/c set up I went through the ID process which from memory was fairly painless once you have your ID with you. You can then use the app to lock/unlock and one or two other minor things - there is a slight delay once you press lock/unlock as it has to go through the authorisation process but it works on mine.
GTI 7.5 Performance 5dr DSG Tornado Red - completely standard spec as - it comes out of the tin as they say
Offline Rudedog
Re: We Connect App
« Reply #11 on: 22 January 2021, 20:59 »
Yep I tried flashing the indicators on mine when I first got it but haven't gone through the ID check yet for the unlock/lock feature.
Quite a lag from sending the request to the actual lights flashing, no idea what network they might use although I'm in a dodgy area for mobile signal at times.
I could see it useful if the key fob stopped working and you didn't want to take the handle apart.
