Author Topic: VW Golf Mk7 - Glow Coil, DPF, flat battery?  (Read 2703 times)
Offline chowe
« on: 13 January 2021, 12:05 »
Alright Team
New to the Golf club, the proud owner of a Lupo for quite a number of years and recently upgraded to a 17 Plate Golf Estate 2.0 TDI. Bought it at 32k miles, with full-service history from a VW garage.
Driven it quite a bit over the Christmas period, lots of long drives for work. Most recently, its started to develop some issues that I hope you can help with:
1. Diesel Particulate Filter light came on, fixed by driving at 31-75mph as per owners manual.
2. A few days -after Glow coil warning light flashing, paired with EM light.
3. Next day- Battery low/ Car refuses to start on the drive.
Error codes that I read:
P2456 - DPF Differential Pressure Sensor
P0299 - Turbocharger/Supercharger Underboost
P2456 - Circuit Intermittant/ Eratic
The dealership has come and picked it up this evening. Hoping the can have a gander.
Anyone with experience/ have a bat at what could be the issue?
Thinking sensor issue, but that doesnt explain the flat battery?
Modify message
Offline chowe
Re: VW Golf Mk7 - Glow Coil, DPF, flat battery?
« Reply #1 on: 13 January 2021, 12:17 »
Note moved from other subforum  :smiley:
Offline fredgroves
« Reply #2 on: 13 January 2021, 12:35 »
Flat battery is quite common these days.
If your battery is 3 years or more old, it probably won't survive disuse over winter.
Get a new battery, clear the faults, make sure you drive it regularly.
And yes DPF's and the current "stay local" advice where you only drive to the supermarket once a week will almost certainly mean DPF clogging issues.
Offline mcmaddy
« Reply #3 on: 13 January 2021, 19:50 »
If you've been doing plenty of long journeys and still got the dpf warning then it could be just a sensor. Hopefully dealer will check status of the battery too 👍
Offline chowe
« Reply #4 on: 13 January 2021, 21:54 »
Spot on, cheers.
The dealer has come back and said it was the sensor. Apparently, the battery issue is a result of the sensor malfunction (however unsure how that would be the case).
