Author Topic: sat nav update - discover media  (Read 14482 times)
Offline fredgroves
Re: sat nav update - discover media
« Reply #10 on: 26 December 2020, 12:50 »
Sounds like it ran out of space during the copy. Make sure you are only copying the right files.. The archive has mib 1 and mib 2 folders, you only need the relevant one...
Offline Ceefeesh
« Reply #11 on: 26 December 2020, 13:34 »
Did you back up your existing maps to a folder before you started? If so then reformat the sd card to FAT 32 which will erase the files on it and it should give you a clean space, sufficient to install the current map. I used bundle 1 maps as it is probably the smallest. Have you tried to identify what the error code means? I have got error messages on DiscoverCare before but it told me it was lack of space and when I reformatted the card it solved the space problem.
« Last Edit: 26 December 2020, 13:38 by Ceefeesh »
Offline Ceefeesh
« Reply #12 on: 26 December 2020, 13:43 »
Thanks for posting that Ceefeesh, you make it sound very easy!
That’s the method I used and I had the update installed in around 15 minutes. It was much more straightforward and quicker than DiscoverCare.
« Last Edit: 26 December 2020, 13:45 by Ceefeesh »
Offline chas.s
« Reply #13 on: 26 December 2020, 13:51 »
Thanks Fred & ceefeesh.
I followed your instructions CF so have saved my 'old' sat nav data.
Regarding the update, I selected the 'European Countries' option which shows to be 14.94gb.
I don't know what the mib 1  or min 2 folders are?
TCR, Pure White, Black roof, Akra exhaust, black 19" Prets, DCC etc.
Gone - 2019, Mk 7.5 PP, 5 door, Manual, Indium Grey, Keyless etc
Offline Ceefeesh
« Reply #14 on: 26 December 2020, 14:26 »
At one stage I saw the size of the upload as 17gb, which I thought was too big because theSD card is 16gb  but when I followed the instructions above, unzipped it and copied it over, it worked. If you have your original maps to revert to, give it a go. “Who dares wins, Rodney”  :grin:
« Last Edit: 26 December 2020, 18:11 by Ceefeesh »
Offline chas.s
« Reply #15 on: 26 December 2020, 14:31 »
 Cheers. I’m now giving it another go, but this time downloading ‘Europe Bundle 1’
Will update you. Chas
Offline chas.s
« Reply #16 on: 26 December 2020, 16:50 »
Just to update you: I have had success downloading the European Countries Bundle 1.
This is showing Version Information:
5NA919866AS
1520
ECE1 2021
I presume that is the latest map available for my Discover Media system?
Thanks for all your assistance. Chas.
Offline Ceefeesh
« Reply #17 on: 26 December 2020, 16:59 »
Yes I think that’s the latest. I bet you feel pleased now! Satisfying!
« Last Edit: 26 December 2020, 17:04 by Ceefeesh »
Offline chas.s
« Reply #18 on: 26 December 2020, 17:05 »
Yes, very pleased.
Thanks.
Offline Rudedog
« Reply #19 on: 26 December 2020, 21:17 »
Just noticed that v13.7 is available so will update later (Map bundle 1 = 14.94Gb)
I know when I did my first update after buying my car at the end of August I couldn't get it to work.
Then I was told to only use the VW card and just delete the old file (remember to empty the trash if using a Mac) then drag/drop the new file which was v12.7 at the time.
