Author Topic: Leaking when opening boot  (Read 13086 times)
Offline greencode
  • Golf R - Pure White
Re: Leaking when opening boot
« Reply #20 on: 22 March 2022, 16:22 »
It's also worth checking the rubber electrical connection boots that go from the car to the top of the tailgate, as these can fail allowing a small gap to open up and letting water in. Just to be on the safe side with mine, at the same time as replacing the drain tube, I also put some black mastic around both boots just to be sure.
Will do. Thanks.
« Last Edit: 22 March 2022, 17:05 by greencode »
