Author Topic: Factory defect which could lead to rust, get checkin  (Read 3921 times)
Offline Mikeyd1
Re: Factory defect which could lead to rust, get checkin
« Reply #10 on: 16 June 2020, 21:07 »
The problem is under the grommets when you pull it out then u should see
2017 gti dsg white silver, 3door, dcc , Brescia alloys, pro Nav dvd ,dynaudio, dcc . Rear tints
Offline Adam T7
« Reply #11 on: 16 June 2020, 21:20 »
Pulled around the edges Up to the edge of the hole - no sign of rust that I could see.
Offline Mikeyd1
« Reply #12 on: 16 June 2020, 21:32 »
Glad to hear hear it. Yep just remove clean and wax it will help seal the grommets right up
Offline Adam T7
« Reply #13 on: 16 June 2020, 21:40 »
Offline Mikeyd1
« Reply #14 on: 17 June 2020, 19:24 »
Checked a 64 plate today there was just a little rust so it doesn’t really seem to spread
Offline Adam T7
« Reply #15 on: 17 June 2020, 21:59 »
If it’s galvanised, it shouldn’t, but worth looking out for either way.
