Author Topic: Free and easy map updates (usually).  (Read 21649 times)
Offline p3asa
Re: Free and Easy. Sat Nav map updates.
« Reply #10 on: 26 May 2020, 12:02 »
Cheers Guys.
Offline Ceefeesh
« Reply #11 on: 26 May 2020, 12:14 »
Yep. That makes sense👍
Offline Eccie
  • Keyless & Penniless
« Reply #12 on: 26 May 2020, 13:09 »
Well I’ve tried again and failed to update the map!
I’ve done everything as per instructions and it never works for me, it clearly isn’t designed for MacBook use :huh:
Offline mcmaddy
« Reply #13 on: 26 May 2020, 13:46 »
if you've got a Mac then you might be better off using the VW update program. I'm sure it does something different on Macs compared to Windows.
Offline Ceefeesh
« Reply #14 on: 26 May 2020, 17:34 »
Hi
I used the Windows option but I saw there is a Mac version for the update too. The first time I tried it did crash but the second time it worked via the DiscoverCare app. On the previous version I could not get it to work no matter what I tried. Good luck.
Offline Ceefeesh
« Reply #15 on: 26 May 2020, 17:40 »
 :smiley:
« Last Edit: 26 May 2020, 17:44 by Ceefeesh »
Offline bogwoppit
« Reply #16 on: 26 May 2020, 18:03 »
I've just done this, thanks to all the posters above.
Car is a 19 reg, and was running Europe 1 (v8) SD card, ECE1 2018 version
I managed to fit the European countries bundle 1 on the factory SD card, so now it is version ECE AS 20/21.
It is worth this topic getting pinned to the mk7 page?
BMW 128ti - current
Mk 7.5 GTI PP, indium grey, manual - gone
Offline Ceefeesh
« Reply #17 on: 26 May 2020, 18:22 »
I thought that’s where it was. If not tell me how to. I think it will be useful for some.
« Last Edit: 05 July 2020, 19:08 by Ceefeesh »
Offline Lordie
« Reply #18 on: 27 May 2020, 19:24 »
Hey. Not sure if this post from the other month might help:
https://www.golfgtiforum.co.uk/index.php?topic=286378.msg2619908#msg2619908
Seems like quite a few people are having issues with these updates so it's a shame VW can't give better and clearer instructions. I wouldn't recommending buying the SD card personally. You'd have to buy 1 or 2 every year whereas if you get it working yourself you can do it every time for free.
Offline Eccie
« Reply #19 on: 29 May 2020, 08:03 »
Ok sorted - VW program is the way to go with a Mac, Incredible slow even on a super fast connection
