Author Topic: Dash Cam suggestion (slightly different)  (Read 5887 times)
Offline rajb
Re: Dash Cam suggestion (slightly different)
« Reply #10 on: 16 January 2020, 07:41 »
Took some quick pics this morning if my F770.
Not the best as was just being quick but not too intrusive.
Offline Sootchucker
« Reply #11 on: 16 January 2020, 08:25 »
Thanks guys, keep them coming.
I did look at the Thinkware units (the F770 and the new 800), because I liked the fact they didn't have a screen (which I hate), but you guys all seem to have the standard housing behind the rear view mirror meaning you can get the unit to "hide" behind the rear view mirror much more effectively. With my setup, the unit would almost have to be in front of the passenger.
Offline monkeyhanger
« Reply #12 on: 16 January 2020, 08:40 »
The F770 does sit nicely to the left of the rear view mirror, hiding it from the drivers view. The passenger can see it, but only 1/3 of my miles are with passengers. Had mine about 4 years in 2 different cars now, and still going strong.
Offline rajb
« Reply #13 on: 16 January 2020, 08:51 »
Yeah agreed that your housing is larger but still think it would work ok. Could be worth seeing if a member isn't too far that you could try placing it where it needs to go to see. Or buy one off Amazon of the like and test it and then return it if you don't want it.
Offline Talk-torque
« Reply #14 on: 16 January 2020, 12:21 »
What I see (Nextbase 522GW):
What the passenger sees:
Roger.
Offline Lordie
« Reply #15 on: 16 January 2020, 18:08 »
I also have a Nextbase 522GW, which I fitted myself. Using the stick on QR mount, I got it to fit behind the rearview mirror so that I can’t see anything of it from the driver’s seat. Your mirror mount and housing looks the same as mine. I had to make up a vinyl patch to cover the sticky mount pad on the outside, as it is creamy white. Looked awful.
Oh great, I've yet to stick mine on with the adhesive mount, been using the suction cup one while I tested the camera out. So didn't realise it was cream  :undecided:.
Any chance of a picture so I can see where you mounted it?. Did it stick to the black dots on the windscreen around the mirror ok?
Sorry to hijack the thread a little
Offline Talk-torque
« Reply #16 on: 16 January 2020, 18:17 »
That’s my installation next post back from yours! 😄 I didn’t want to stick it to the dots, as I wasn’t sure whether it would stick well but, if it did, would it pull the dots off when I remove it.
Roger.
Offline Lordie
« Reply #17 on: 16 January 2020, 18:57 »
Oh I didn't see there was a second page. First of all that is nicely installed and very well hidden. Secondly, damn! :grin: You have a different mirror layout to my one.  Mine doesn't go into a point like yours so it's harder to hide the camera, especially without sticking to the dots.
I stuck my dashcam on the dots on my last car so might just slap it on there so it's perfectly hidden behind my mirror (I hope there's enough space). Even if I did stick it to the dots and remove it, I would put another dashcam on in exactly the same place.
How come your's doesn't have the big magnet thing on the power cable to avoid interference? Didn't you install it?
I've never seen that F770 cam before :huh:. Looks very nice a sleek, no screen tho? I'd miss that.
Also OP, you can get one with a screen that just turns off after 15/30/60 seconds (depends on brand).
« Last Edit: 16 January 2020, 19:00 by Lordie »
steve12345
« Reply #18 on: 16 January 2020, 19:35 »
I use a Mobious camera, installed behind the rear view mirror. its pretty much invisible to the driver. the passenger will see it but its very discrete.
Its a very basic camera, but the picture quality is brilliant, even at night. No screen, no wifi or other fancy features.
I discovered this a while back when i had a 1 series, and when switched cars i kept the camera and fit it in the same way onto the GTI.
here is the thread where i discovered it, brucealmightys post on the below link has some pictures that should give you an idea how it looks installed.
https://www.babybmw.net/viewtopic.php?f=63&t=80200&hilit=mobious&start=60
Offline mcmaddy
« Reply #19 on: 16 January 2020, 20:25 »
what do you need a screen for? Thinkware have got a mobile app that shows you your footage. Thinkware and Blackvue are the best dash cams you can buy. The night footage on the f770 is superb.
