Author Topic: Brake upgrade recommendation  (Read 2831 times)
Offline daveybrown1991
« on: 28 December 2019, 18:39 »
Hi people,
My GTI PP is due a brake fluid change and the discs and pads are nearing needing replacement.
I was just wondering if people had any recommendations on upgrade on brake fluid, discs & pads and whether its worthwhile.
If so what do people recommend at a reasonable price?
I don't use the car on track, but the car is running stage 1 remap.
Thanks
Offline Ryan90GTI
Re: Brake upgrade recommendation
« Reply #1 on: 28 December 2019, 19:37 »
I've gone with Clubsport S discs with redstuff pads.
Offline clubsport
« Reply #2 on: 28 December 2019, 20:32 »
For road use, I would think a pad upgrade with the standard discs would be fine.
You are unlikely to get enough temperature in the brakes with road use to warrant an upgrade to Dot 5 fluid over regulat Dot4.
I have not heard great things about the CS S discs on track, they may be fine for road use, but don't save much weight over standard PP discs?
Offline Craig
« Reply #3 on: 29 December 2019, 10:04 »
Looking at the DAP videos online the TT RS brakes are a direct fit and if you can get the calipers secondhand you would have a proper massive brake upgrade.
Will be going down this route in the near future for my CSS.
Offline Tornado8
« Reply #4 on: 29 December 2019, 11:26 »
I need to change discs and pads too. I have been looking at Brembo and Tarox upgrades, but is the consensus you only need to upgrade the pads if your only using for fast road use. I have Revo stage 2 and   steel brake hoses.
Old, but a serial modder!
Offline Ryan90GTI
« Reply #5 on: 29 December 2019, 14:01 »
Think it's almost 1kg weight saving per disc. There's quite a few on the Audi forum who run CSS discs with Redstuff/Yellowstuff pads.
Offline clubsport
« Reply #6 on: 29 December 2019, 14:30 »
Please report back how good the car feels after saving 1kg on a disc brake.
Using the same wheels and pad compound as before I would not be able to tell.
Offline Ryan90GTI
« Reply #7 on: 29 December 2019, 14:35 »
Weight comparisons:
- STOCK 340x30mm disc - 10.7kg (per disc)
- Clubsport S 340x30mm disc - 9.8kg (per disc)
Offline Ryan90GTI
« Reply #8 on: 29 December 2019, 14:42 »
I'd like to think with a set of lightweight wheels like the Belvederes and this disc and pad combo it'll make for a decent enough set up for road use. It'll certainly be more than adequate for my needs.
Offline mike roberts
« Reply #9 on: 30 December 2019, 21:48 »
Weight savings in wheels are much more beneficial because of rotational mass. Something like a x4 effect.
Anyhoo. Endless MX-72s on plain discs with decent pads and fluid. Work fantastically from cold; no noise, rattle or excessive dust and they'll handle a track day like a champ. Spendy up front, but last soooooo long. So cost per mile is pretty much the same as cheap tat.
'18 245PP DSG
