Author Topic: Aftermarket Exhaust - GTI PP  (Read 8295 times)
Offline Ryan90GTI
Re: Aftermarket Exhaust - GTI PP
« Reply #20 on: 20 December 2019, 23:36 »
Some really good informative posts about the mod, there's not much more to say really. I got mine from Latvian seller on eBay, worked out at £387 in the end.
I've got the TCR rear spoiler on its way as well as the Clubsport S rear valance which should finish the rear off just nicely.
I don't want to fit everything now because it'll get dirty 😂
Offline hoggeh
« Reply #21 on: 21 December 2019, 02:14 »
As I said in the previous post I really would fit it sooner rather than later, it definitely gets better with miles through it.
I was initially puzzled that I may have spent good money for not much difference but as you put the miles on it the break in happens. People say that it gets better and better, I am currently at around 2k miles on it and the heat cycles do definitely make a difference.
Not to sound like a broken record I would get it on asap so it'll break in sooner for you.
Offline king monkey
« Reply #22 on: 21 December 2019, 07:06 »
The TCR rear lip spoiler is a brilliant addition. Never regretted getting one. Finishes the car off so subtly.
Offline Ryan90GTI
« Reply #23 on: 21 December 2019, 09:52 »
Putting miles on it won't be a problem with the distance I cover every month. I'll get some sound clips of it when I do fit it to compare it with the standard exhaust.
Offline Love43
« Reply #24 on: 01 January 2020, 05:53 »
I have a miltek resonated cat back system with titanium tips that I no longer need if anyone is interested ?
Was fitted to my 2013 mk7 GTIi PP same fitment I believe as standard GTI !
Offline candy turbo
« Reply #25 on: 02 January 2020, 18:50 »
i have a clubsport S and i thought it was a bit quiet , fitted a res delete and it sounded crap , i had a smaller than oem resonator put back in , it sounds perfect now but may get too loud as it beds in , car only done 1200 miles
clubsport S no 215
Offline Ryan90GTI
« Reply #26 on: 02 January 2020, 18:55 »
If you want, I'll gladly help you to double that mileage by the end of the month - FOC.  :tongue:
Offline Willk86
« Reply #27 on: 03 January 2020, 16:07 »
Where are you located and how much are you after for it?
