Author Topic: Disable headlamp washer system ?  (Read 20765 times)
Offline SRGTD
Re: Disable headlamp washer system ?
« Reply #20 on: 16 December 2019, 12:44 »
I always think that headlamp washers are pretty ineffective at doing what they should do - i.e. clean the headlamp lenses - they do a brilliant job of spraying washer fluid all over the bonnet though!  IMO, for headlamp washers to be effective, they’d need a set of headlamp wipers as well, like the 1980’s BMW’s and Saab’s had, although modern headlamp lenses being made of polycarbonate, presumably headlamp wipers would inflict scratches on these plastic lenses.
The current VW Polo models with LED headlamps don’t have headlamp washers (not a requirement if their light sources emit less than 2,000 lumens). The Polo’s winter pack doesn’t include headlamp washers either. Based on pictures of the forthcoming mk8 Golf, it doesn’t have headlamp washers (no pop up covers in the front bumpers where the washers would be if they were fitted) - even with the LED matrix headlamps.
So even though the jury’s out on the looks of the mk8 Golf’s front end, at least there won’t be the annoyance of washer fluid being sprayed all over the front end of the car when washing the windscreen with the headlights on.
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline Finglonga
« Reply #21 on: 16 December 2019, 13:38 »
Where are you located OP?
Offline boardlord
« Reply #22 on: 16 December 2019, 14:58 »
I assume they have a seperate pump? Can it not just be unplugged or have the fuse pulled?
2019 MK7.5 GTi PP, 3dr, DSG, Indium Grey, Heated screen, Pan roof, 90% tints.
Offline martin998877
« Reply #23 on: 16 December 2019, 22:06 »
Hi, I live in Wolverhampton and work in Stoke on Trent.  I'd be happy to pay someone to recode them - it would pay back in a month with the amount of washer fluid I'm getting through!
Golf GTi Mark 7 owner
Offline fredgroves
« Reply #24 on: 17 December 2019, 09:16 »
Its winter... you use a bit more washer fluid than the summer, well, apart from bug season.
I don't know what you are using for yours, but I am using some Halfords concentrate and the rest is water. Works fine.
I do loads of motorway miles, but even I am only filling the thing up every couple of weeks and it costs me pennies...
I'm a tight git but really...
Offline dean5125
« Reply #25 on: 17 December 2019, 10:02 »
 :grin: I have to agree.... this all seems a little excessive, talk of sabotaging the washer system, driving miles to have some coding done..... really mate, you can't possibly be using that much can you?!?
My only annoyance is after you've washed the car in winter and have to use it for the first time, even more grating when its the guy in front that does it to you!
What about a boot modification and have a 25 gallon drum fitted and plumbed in to the system? :whistle:
2019 (68) GTI PERFORMANCE DSG - new baby
2016 (66) GOLF R DSG - gone but definitely not forgotten
« Reply #26 on: 17 December 2019, 12:11 »
The point is, the headlamp washer system uses a lot of washer fluid, doesn't actually make the headlamps clean, dumps washer fluid all over the bonnet and causes unnecessary excessive use.  As a high mileage driver a 3l or 5l tank of washer fluid used to last ages in previous cars, now it goes within a week.  Thank you to those people with helpful ideas and for the discussion.
Offline dubber36
« Reply #27 on: 17 December 2019, 16:10 »
My wife always gets through way more screenwash than I do. Whilst she doesn't tailgate, far from it, she does follow traffic much closer than I do. Just saying  :wink:
Offline Talk-torque
« Reply #28 on: 17 December 2019, 17:02 »
I don’t think OBD11 will work on your wife. 😟
Roger.
Offline Finglonga
« Reply #29 on: 18 December 2019, 08:39 »
I live near Stafford so would be able to work something out for you to get it sorted for you no problems.👍.
