Author Topic: brake discs  (Read 5422 times)
Offline Carbon VW
Re: brake discs
« Reply #10 on: 02 November 2019, 10:58 »
after 4 weeks now the front  discs have again warped this is bugging me now , last option is to get the genuine vw discs and pads, could this just be cheap metal in the disc the ones on are brembo and brembo pads please help me
Hi mossy. I just fitted Brenbo discs and pads all round and they have been great on my car since fitted. They look and feel very good quality so I don’t think you should be blaming the brembo parts. As others have said, you need to get the suspension setup checked and the callipers for sticking. Hope you get it sorted
Mk7 CSG GTi 6MF Stage 1, CSS backbox
Offline mossy69
  • 2014 Gtd carbon grey pro nav dyn audio keyless wp
Re: brake discs
« Reply #11 on: 03 November 2019, 20:05 »
will do ill ring the stealers in the morning visa at the ready
2021 Gti moonstone grey 19 Adelaide HUD winter pack
2014 GTD carbon grey pro nav dyn audio keyless
Offline b33fys
Re: brake discs
« Reply #12 on: 05 November 2019, 22:33 »
Sounds like a sticky caliper?
But then again, you’d think the mechanic that fitted the brakes in first place might of noted a tight piston huh. Not sure, but I’m interested. Hope you get it fixed.
« Last Edit: 05 November 2019, 22:37 by b33fys »
Offline mossy69
Re: brake discs
« Reply #13 on: 15 November 2019, 16:36 »
rang a German car specialist today its going in for a diagnostic scan next week I told him the problems I've had and he mentioned it could be the rear discs warped not the front ones I've had replaced ,he said it also could be the abs pump ,,,any feedback on issues of this sort wound be appreciated cheers once again
